Donate Now Goal amount for this year: 3000 USD, Received: 2290 USD (76%)
Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 24
Like Tree6Likes
Thread: Replace the actual value of a dimension
  1.    #11
    8,842
    08:07 PM
    Sounds to me like the *Detail/Section* is a Drafting View, and not a Live Section. Theres a lot to be done differently, if thats the case:
    1. Use a modeled Section/Detail
    2. Dont fake dimensions
    3. Be happy.
    elton williams likes this.
  2.    #12
    December 3, 2012
    Fernandina Beach, FL
    47
    09:07 PM
    I seen anyone who asks this go up in flames. I have to ask tho, we in the architecture field do use +/- F.V., CLEAR or Min, Max....all the time for communicating intent. I see I can add these with the prefix. But then again, I set my tolerances as high as they go and sometimes I just want to run the override to up the precision like I could in Autocad. This has bit me when walls all of the sudden arent parallel and wont dimension. So I understand the where the backlash is coming from, but I wish I had a tad more flexibility and control. I get that this is not a 2d line. Totally understood.
  3.    #13
    8,842
    08:07 PM
    Quote Originally Posted by stevenpapke View Post
    FV, CLEAR, MIN, MAX, I don't have any issues with. The OP mentioned inserting a character code for a blank character, which is only required if Revit is trying to stop you from replacing a dimension with a faked dimension value made out of text. Which- in my humble opinion (and at my company)- is literally a fireable offense.
    There's no place for that in the profession. There wasn't when I was doing jobs in architecture, either.
    Aaron Maller
    Director
    Parallax Team, Inc.
  4.    #14
    October 16, 2016
    242
    01:07 AM
    Hello all,
    Yes I actually created a Drafting view in which I place a section of the door and the floor plan of it.
    The reason why I create a drafting view for the door and I didn't make a 'Live section' is that I have created some 2D details for the doors (the fixe part etc..), so In the model the door that I have place don't match with the doors that I actually want to have.
    Tell me if you have to propose me something else.
    Thank you in advance!
  5.    #15
    June 21, 2012
    Tours, France
    677
    03:07 AM
    Quote Originally Posted by MARIA1993 View Post
    'Live section'
    What are you calling a "Live section"?
  6.    #16
    October 16, 2016
    242
    01:07 AM
    A normal section using the section command.
  7.    #17
    June 21, 2012
    Tours, France
    677
    03:07 AM
    ok Understood, I've never heard about that name before!
  8.    #18
    January 27, 2017
    North Dakota
    72
    08:07 PM
    Put the door in that you want instead. If I received a model that was designed the way you are doing this I would be sending it back to you to fix it or hold you liable for any errors in construction.
  9.    #19
    October 16, 2016
    242
    01:07 AM
    Quote Originally Posted by mhoard View Post
    You mean to have exactly the same door both in detail in floor plan?
    My problem is that for the floor plan I don't have this kind of door in 3D.
    I have the details only in 2D.
    Thank you for your answers!
  10.    #20
    Coeur d Alene, ID
    4,237
    06:07 PM
    I need this 'cheat' in the details. When I create the detail for a door in a section view I don't have a lot of space to put the real height of the door so I make a section. After I need to edit the dimension for the ' empty passage' in order to correspond to the reality.
    Maria, the best option for this is to create a dimension style that makes the text be as small as possible and make it so it sits right on the line. You will have to add text yourself above the line. No cheating the actual dimension with unicode characters, it's like you're just using a family that creates dimensions.
  1. Dimension strings not adding up to the total length dimension string (2017)
    By ledgewood33 in forum Architecture and General Revit Questions
    Last Post: March 26th, 2018, 03:24 PM
  2. Dimensions: Dimension Movement , Dimension Breaks
    By Usernumerouno in forum Architecture and General Revit Questions
    Last Post: October 7th, 2015, 08:15 PM
  3. Actual VS Nominal
    By Shields08 in forum Architecture and General Revit Questions
    Last Post: May 17th, 2013, 07:11 PM
  4. Need help. Actual project.
    By r7_human8y in forum Architecture and General Revit Questions
    Last Post: December 1st, 2011, 04:54 PM
  5. temporary dimension (dimension snap) remains large and off screen when zooming in
    By birdnehru in forum Architecture and General Revit Questions
    Last Post: October 27th, 2011, 06:25 PM
