Our project will be tendered and built over 4 phases (not including demolition as a phase). However the Building Consent will cover all phases at once.
I'm proposing to complete the BC documentation with everything set to New Construction phase, and only then create the 4 different phases and change the elements to each appropriate phase.
Is this the best approach? It does mean reworking things a fair bit to get each phase documented correctly.
Thanks
