Page 1 of 2 12 LastLast
Results 1 to 10 of 19
Like Tree9Likes
Thread: grids and levels as a workset or a design option??
    November 18, 2016
    41
    03:11 AM
    ok oracles, we are having a steering group meeting and the discussion is of whether grids and levels should be a workset or a design option? what is the consensus on here? are there pros and cons for both ways? generally we are using revit for single building multi-storey commercial and resi projects from stage 4 onwards when the grid is usually set.
    9,411
    09:11 PM
    Quote Originally Posted by robp View Post
    They do entirely different things.
    If the project is workshared at all, the grids have to go on SOME workset. Doesn't mean they have to be on their own, but it doesn't hurt.
    Design options for grids are handy if you want to "lock the down" so people don't accidentally move them. But I find the practice annoying.
    The thing is (my professional opinion) if you're talking about EITHER as a visibility control, you're going down the wrong path. You simply don't need to use worksets for visibility. And if someone is talking about DESIGN OPTIONS for visibility... Punch them.
    Aaron Maller
    Director
    Parallax Team, Inc.
    snowyweston, robp and kirklyncox like this.
    November 18, 2016
    41
    03:11 AM
    Thanks twiceroadsfool, it isnt a visibility thing more of a "lock down" thing.
    December 21, 2010
    C.LONDON
    4,274
    03:11 AM
    Meh.
    Can't add much more to Aaron's advice (note I use DOs for viz. tricks a lot, but that's a different thread) - but I certainly advocate a workset for ALL datums (that's grids, levels and any other site/project-defining constraint, element, or natty widget, etc).
    For viz. control... EVERYTHING is about filters (we use 5 different level types and 2 different grid types so have it all fairly cemented in our workflows)
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    2,624
    09:11 PM
    One of my favorite sayings: What's the question behind the question?
    What are you trying to accomplish with either Worksets or Design Options?
    If you want to lock down the Grids, DOs are probably the way to go.
    If you're trying to control Visibility with a Workset, I'm with Aaron. Bad idea.
    December 21, 2010
    C.LONDON
    4,274
    03:11 AM
    Pin them and when you walk the room keep a keen eye out for users who don't have the five Xs...
    zeekeey likes this.
    December 21, 2010
    C.LONDON
    4,274
    03:11 AM
    Even when well-managed and assigned to Scope Boxes, "the DO-veil" is an utter nuisance for 2D/3D-extent-switching/dragging in views. Trust me, I/we tried... and will never do it again.
    November 18, 2016
    41
    03:11 AM
    *sits back and waits for punch-up
    May 18, 2011
    Calgary, AB
    334
    08:11 PM
    Keep it simple. Worksets and run a Dynamo graph regularly to pin them. Assign one person as the grid and level person to add/delete/adjust.
    Levels and grids could be in there own model, but you still have to copy them into your project, monitoring is up to you. At least if things do move, your more than likely to have one version of the truth to fall back on. I don't bother with a separate model for smaller projects... I just carry a big stick for the small projects (may or may not have rusty nails on the end).
    snowyweston likes this.
    December 21, 2010
    C.LONDON
    4,274
    03:11 AM
    Quote Originally Posted by cheinaranta View Post
    Provides a very nice 'baseline' and a nice n' light coordination/setup model - so definitely worthy of consideration for more involved projects.
    cheinaranta likes this.
  1. Copy/Monitor Grids in a Linked file in a Design Option
    By CHolden in forum Architecture and General Revit Questions
    Last Post: September 15th, 2015, 02:57 PM
  2. Replies: 0
    Last Post: June 10th, 2015, 07:15 AM
  3. grids and levels
    By leetecture in forum Architecture and General Revit Questions
    Last Post: October 18th, 2012, 01:27 PM
  4. can we change design option to another option ??
    Last Post: July 8th, 2012, 07:29 PM
  5. Replies: 0
    Last Post: July 13th, 2011, 10:10 AM
