Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By Twiceroadsfool
Thread: Get Count % in Schedule
    Arsham
    Guest
    i have 129 unit and 5 unit types, i created a schedule and sorted them by Unit Types,
    now what i want is to create another column which shows the percentage of each unit type based on the total,
    any ideas? thanks
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    2,962
    11:39 PM
    This thread may help
    https://www.revitforum.org/tutorials...-schedule.html
    Not exactly what you're trying to do, but I think you should be able to adapt the concept.
    10,100
    11:39 PM
    You actually dont need a formula to do it at all. Just make a Calculated Value, and set it to "Percantage" instead of Formula, and make it a "percentage" of "Grand Total."
    Arsham
    Guest
    it won't let you to select Count as % of Grand Total.
    Arsham
    Guest
    it doesn't let me select Count for %, in order to do that, i have to combine it with another parameter,
    and then the issue is that i can't use a combined parameter in formula.
    Arsham
    Guest
    ok , what i need to do is to create a new number parameter, select all the rooms and set that parameter as 1 for all of them,
    then it'll let me select the new parameter in a calculated value as a percentage.
    thanks guys.
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,119
    12:39 AM
    You need a dummy parameter to take the place of Count:
    https://www.revitforum.org/blog-feed...-schedule.html
    10,100
    11:39 PM
    Sorry, i forgot about that. To work around it i have a Shared Parameter called item_Count, and i used the Family Processor to go through my entire damn library, and set that value locked to 1 in every family i have, LOL. Makes using Count in a formula a bit easier.
    cellophane likes this.
    July 31, 2017
    1
    04:39 AM
    If you don't want to add share parameters and all that just add a calculated value as Count: If(Area > 1,1,1)
    Then do the percentage from this one
    You don't need to update parameters or do anything else
    Senior Member ekkonap's Avatar
    May 23, 2011
    Netherlands
    576
    06:39 AM
    A fixed Calculated Value does not really need a formula. Just write a '1'.
  1. Sort Schedule by Count
    By Joshua Kohl in forum Architecture and General Revit Questions
    Last Post: June 30th, 2015, 06:13 PM
  2. Suffix behind count in schedule
    By boriskam1991 in forum Architecture and General Revit Questions
    Last Post: November 21st, 2012, 06:31 PM
  3. Schedule Count Question
    By mikey1073 in forum Architecture and General Revit Questions
    Last Post: September 19th, 2012, 04:19 PM
  4. Replies: 0
    Last Post: April 18th, 2012, 07:15 AM
  5. Schedule: Count only what's shown in schedule...
    By rkitect in forum Architecture and General Revit Questions
    Last Post: July 17th, 2011, 03:57 PM
