Page 1 of 2 12 LastLast
Results 1 to 10 of 15
Like Tree4Likes
Thread: Assembled Stairs - once again..
    Member BLothian's Avatar
    December 11, 2013
    Livingston, Scotland
    464
    05:00 PM
    Angry Assembled Stairs - once again..
    Another project, same old stair issues being encountered yet again;Stair by component doesn't seem to be able generate the double winder stairs I am commonly having to create (constant error messages no doubt related to the narrow winder arrangement I'm trying to achieve at the newel post which complies to my local building regulations)so I have to revert to using sketch run:
    • Risers: In a way its the preferable option to me anyway as I can precisely place the risers where I want them to be. Now apply a nosing profile and set its length and instead of the nosing moving forward of the sketched riser, the riser moves backwards.
      WTF Autodesk ?
      The sketch run tool clearly states Riser (sketches lines to define the risers for a run of stairs). Surely the tool option should state tread (not riser) as that's the only thing that stays constant to the sketched line and the parameter Nosing Length be renamed to riser offset (because its the riser that's moving)?
    • Stringers: I also find the automatic stringers don't work as I'd like either so I turn them off. I've read others use Generic Models or In-place Models though my preference is to create a single wall type, draw it full height and edit the profile. I prefer it over In-place as I don't have create named ref planes for each extrusion nor is my stair families category in the browser cluttered up with 1 type per piece of stringer. What method do you use?
    December 13, 2010
    Ambleside, Lake District, UK
    921
    05:00 PM
    Hi BLothian,
    i can only sympathise - I've never found it easy to do winder stairs (or indeed ramps) in Revit - it takes persistence and a lot of trial and error - and as you say the sketch method is the more flexible and reliable, once the geometry is drawn out in 2D underneath.
    The newer stair method always seems not quite finished - as though the programmers meant to come back to it, but haven't so far.
    (FWIW I once worked at Livingston Development Corporation)
    December 11, 2013
    464
    05:00 PM
    Hi Will,
    Yeah its a bit frustrating but to have to break the stair down into different parts to get the desired modelled staircase.
    Quote Originally Posted by willsud View Post
    Small world indeed. A lot has changed up here since the LDC was last around, I don't suppose you are familiar with the notorious LDC houses that used Siporex concrete are you?
    December 21, 2010
    C.LONDON
    4,339
    05:00 PM
    Quote Originally Posted by BLothian View Post
    (my local building regulations)
    Is that a devolution thing?
    December 13, 2010
    921
    05:00 PM
    No, not guilty of those - I was a 'year out' student from Edinburgh Uni and worked on a sports centre mostly - it was eventually shelved I think.
    December 11, 2013
    464
    05:00 PM
    Haha no, merely just that my (national) Building Regulation's are local to me (given that this forum is international). I don't think I'd be keen on regional building standards with minor differences.
    snowyweston likes this.
    December 11, 2013
    464
    05:00 PM
    One thing I had forgotten about and not really considered is how create the finished ceiling under the winder part of the stair. I've searched past threads and the common line of reply was to use a monolithic stair however I have already been progressing assembled stairs. I've also looked into real world construction methods to create the ceiling, those also vary:
    • one method is to pack the underside of risers and treads with as much quilt insulation as possible and then secure a sheet of dense chicken wire mesh which can be shaped prior to receive multiple applications of plaster to create an organic smooth surface.
    • Another is using framing and pieces of gypsum wallboard or finish timber to create a faceted finish.
    FWIW: I did duplicate a flight of stairs and change it to monolithic and whilst I did see the curve underside, there was a nasty vertical joint and the intersection between the winders underside and straight run underside. I had though of trying to create a mass of the winders underside using it as a template so to speak, however my experience with masses it almost none so I don't know it that idea has any prospect of success. The other consideration was shape-editing roofs/floors though I imagine that would take quite a bit of trial and error.
    I was wonder how you all go about dealing with this issue as really don't want to leave it open just because I wasn't sure how to model it.
    December 13, 2010
    921
    05:00 PM
    I've tended to leave it alone in terms of modelling as often it doesn't appear in Views, however on occasion I have done what you have described.
    This isn't unique to Revit - I had a job years ago when I used Allplan and created this interior for a barn conversion for an eminent academic client who was a bit obsessive and insisted the joiner recreate the modelled stair design absolutely accurately.
    At the party to celebrate completion I didn't have the heart to tell the joiner that the funny kink in the stair stringer was caused by Allplan not being able to model the string going round the corner properly - and to his great credit he copied it faithfully in the real stair string
    cganiere likes this.
    December 21, 2010
    C.LONDON
    4,339
    05:00 PM
    Quote Originally Posted by kevinraymund View Post
    Can anybody help me with the Stair issue I'm encountering please.
    Perhaps, but in a thread of your own... one mo...
    Junior Member MrScotte's Avatar
    February 13, 2018
    Galveston, TX US
    10
    12:00 PM
    This is a major Bummer! All this time I was thinking if any program could do a mirrored array of stairs it would be REVIT 2018. Well, guess there there is always SketchUp. Let’s know where you take Thread Snowy? I will follow.
  1. [Stairs] Unexpected cutting steps in stairs
    By woszer in forum Architecture and General Revit Questions
    Last Post: January 6th, 2018, 07:22 PM
  2. Structural stairs from architectural stairs
    By wpnc79 in forum Structure - General Questions
    Last Post: October 31st, 2016, 03:28 PM
  3. Stairs. Damn stairs.
    By Jaime in forum Architecture and General Revit Questions
    Last Post: June 24th, 2015, 07:24 PM
  4. Stairs
    By mona miller in forum Architecture and General Revit Questions
    Last Post: May 6th, 2014, 03:58 PM
  5. Some serious stairs help.... please
    By Alfienoakes in forum Architecture and General Revit Questions
    Last Post: February 13th, 2012, 02:59 PM
