Results 1 to 2 of 2
Like Tree2Likes
  • 1 Post By dylanrevitq
  • 1 Post By cliff collins
Thread: How do I create a Y shaped column?
    January 21, 2015
    16
    01:46 PM
    I'm trying to make the below as a column family within Revit. Instead of it looking so wishboned shaped, I'm just trying to make it as tubular as possible except for the center part where I'm trying to blend both mirrored circular angled blends together.
    'I feel like I'm going crazy. I tried to create a blend, mirrored it in order to get the Y shape, but then can't get a swept blend to make a nice curvature inbetween the two.
    Any suggestions?
    Attached Thumbnails Attached Thumbnails How do I create a Y shaped column?-15354_image_3.jpg
    esaulbueno likes this.
    St. Louis, MO
    1,954
    07:46 AM
    dylanrevitq likes this.
  1. Arc Column shape how to create?
    By dedo in forum Structure - General Questions
    Last Post: August 18th, 2016, 06:26 AM
  2. Can this be done? (L-shaped retaining wall with sloping base/Tilted L-shaped wall)
    By Glenn Arne in forum Architecture and General Revit Questions
    Last Post: January 27th, 2016, 10:58 PM
  3. How to create own family: C channel as column
    By vccy in forum Structure - Family Creation
    Last Post: October 20th, 2015, 11:13 AM
  4. create a tapered steel column
    By pplusd mikef in forum Structure - General Questions
    Last Post: August 2nd, 2013, 07:37 AM
  5. How to create SHS steel column
    By Yan Naing Bo in forum Structure - Family Creation
    Last Post: May 30th, 2012, 03:03 PM
