Results 1 to 3 of 3
Thread: how to calculate the surface area?
    September 10, 2011
    1
    09:59 AM
    How to calculate the lateral of column surface area which is visual?
    TKS!
    Attached Files Attached Files
    Nantes, France
    1,380
    11:59 AM
    you can use paint by face, using a material named Visible_col_area, then make a material schedule.
    otherwise, you will have to deal with calculated values with shared parameters, but it will be hard to have only visible area.
    good luck.
    Orlando, FL, USA
    3,111
    05:59 AM
    Yes, as Julien said, paint the surfaces, then create a material take-off schedule.
    Also, for take-off schedules, please refer to:
    http://wikihelp.autodesk.com/Revit/enu/2012/Help/Revit_User's_Guide/1394-Document1394/1476-Schedule1476/1483-Material1483
    Attached Thumbnails Attached Thumbnails how to calculate the surface area?-area-surfaces.jpg
  1. Room and Area Calculations - Calculate Ratio
    By mdradvies in forum Tutorials, Tips & Tricks
    Last Post: June 8th, 2017, 12:28 PM
  2. Replies: 15
    Last Post: July 31st, 2014, 07:24 PM
  3. Help with area selection
    By sharons in forum Architecture and General Revit Questions
    Last Post: June 20th, 2011, 10:57 AM
  4. Concrete Beam surface Area Schedule - Problem
    By G Jowett in forum Structure - General Questions
    Last Post: February 15th, 2011, 09:54 PM
