Page 1 of 4 1234 LastLast
Results 1 to 10 of 33
Like Tree20Likes
Thread: Wall wrapping at abutment (wall thickening)
    Junior Member ju_jigsaw's Avatar
    December 20, 2013
    Cheshire, England
    12
    12:33 AM
    I am trying to join a 100mm blockwork wall with a dry lined plasterboard finish to a thicker wall (440mm blockwork) of the exact same build and get the wall dry lined finish to wrap correctly (at 'x') to show the dry lining wrapping around the wall. All looks fine before I join the walls together but when I do wrapping is missed on the return abutment to the thinner wall. I've tried everything I know but cannot get it to work.
    Anyone got any ideas?
    Attached Thumbnails Attached Thumbnails Wall wrapping at abutment (wall thickening)-wall-wrapping-abutment.png   Wall wrapping at abutment (wall thickening)-wall-wrapping-abutment.png
    St. Louis, MO
    1,954
    06:33 PM
    Try experimenting with:
    Wraps at Ends in Wall Properties
    Disallow Join-right-click blue dot at end of wall
    December 20, 2013
    Cheshire, England
    12
    12:33 AM
    Almost! Thanks for the idea but doesn't quite work. I have tried all options for wraps at end in properties with no joy. I'm convinced there's something odd going on.
    Attached Thumbnails Attached Thumbnails Wall wrapping at abutment (wall thickening)-wall-wrapping-abutment1.png
    December 21, 2010
    C.LONDON
    4,339
    12:33 AM
    Quote Originally Posted by cliff collins View Post
    Then model it all using separate elements.
    St. Louis, MO
    1,954
    06:33 PM
    Senior Member Charles Karl's Avatar
    December 6, 2011
    Fairbanks, Alaska
    962
    03:33 PM
    I have had to do this and works well, wish it were automatic though.
    December 20, 2013
    Cheshire, England
    12
    12:33 AM
    So what I'm getting from all this is that Revit cannot natively do something seemingly really, really simple and that occurs in millions and millions of buildings around the world??!! Wow, just wow.
    Siiiggghhhhh........Every time I dip my toe back into Revit something like this crops up, something simple yet almost impossible, just to remind me why I loathe Autodesk and the way they develop their software.
    Does anyone from Autodesk even bother to come to places like this and get some hints about how they could actually make their software products easier to use, more user friendly and maybe efficient? I'm guessing not.
    So disappointed.
    9,765
    06:33 PM
    If you are THAT upset about something like Wall Joins, i cant imagine you're going to enjoy working in Revit at ALL.
    Having said that, for a number of OTHER reasons i would have those modeled as separate walls anyway. At which point they look perfectly correct.
    December 20, 2013
    Cheshire, England
    12
    12:33 AM
    Quote Originally Posted by Charles Karl View Post
    To do this do you just make a wall from just the timber battens and plasterboard (i.e. one sided with no masonry core) and then align it to sit on the face of the end of the thicker blockwork wall?
    December 20, 2013
    Cheshire, England
    12
    12:33 AM
    I wouldn't say upset, just perpetuity disappointed that things like this in Revit are no further on than they were 10yrs ago. Autodesk are asleep.....or just sat there counting their money.
    With regards to modelling as separate elements how would have split the wall? I'm happy to go down this route, just need to be pointed in a direction. What also are those other reasons, I'd like make sure I'm approaching all this in the correct way.
  1. Wall end wrapping diferentiated
    By juca64 in forum Architecture and General Revit Questions
    Last Post: November 28th, 2016, 04:44 PM
  2. Wall end wrapping at angle different from 90 degrees
    By Dario90 in forum Architecture and General Revit Questions
    Last Post: September 20th, 2016, 09:33 AM
  3. Wall finish with wrapping
    By ebow3d in forum Architecture and General Revit Questions
    Last Post: April 11th, 2016, 02:22 AM
  4. Wrapping A Profile On A Wall
    By JD003 in forum Architecture and General Revit Questions
    Last Post: May 2nd, 2015, 05:14 PM
  5. Wall wrapping Question?
    By LAbraham in forum Architecture and General Revit Questions
    Last Post: June 24th, 2014, 06:58 PM
