Results 1 to 7 of 7
Like Tree2Likes
  • 2 Post By GMcDowellJr
Thread: Trying to join a wall finish to a wall with an opening. Doesnt play nice
    August 31, 2011
    159
    01:44 PM
    I have joined a wall finish to wall that has an opening but the wall finish is ignoring the wall opening. is there any way to get around this other than creating another opening in the wall finish?
    9,671
    07:44 AM
    It depends on how the opening was made:
    Opening Tool: no, youll need another one.
    Component with Opening in it (Door, Generic Model Family): It should cut through both
    Component with Void in it (Door, Generic Model): Only if the void is deep enough to cut both.
    Member duende123's Avatar
    November 20, 2015
    186
    08:44 AM
    .....and it is necessary to join both walls ¿No?
    9,671
    07:44 AM
    Yep. They mentioned they had joined them already, so i didnt say it again.
    December 21, 2010
    Phoenix, AZ
    2,428
    06:44 AM
    Shoot... people around here say "tag" all day long but really mean text with a leader! You keep using that word, I do not think it means what you think it means.
    cganiere and elton williams like this.
    St. Louis, MO
    1,952
    07:44 AM
    There is also the option of using Edit Wall Profile for the finish wall, and lock the sketch lines to the opening. But that method is somewhat controversial.....
    Gold Coast
    2,450
    11:44 PM
    Quote Originally Posted by cliff collins View Post
    Just because you can, doesn't mean you should
  1. After Joint between wall and column, wall length doesnt decrease.
    By walwarine in forum Architecture and General Revit Questions
    Last Post: January 10th, 2018, 07:29 PM
  2. Foundation Wall to Finish Wall Construction
    Last Post: February 18th, 2016, 05:05 AM
  3. Beam Doesnt Cut The Wall
    By Uzun in forum Architecture and General Revit Questions
    Last Post: July 15th, 2013, 04:21 PM
  4. Curved wall opening / faced based family opening to curved wall
    By tjgreatrex in forum Architecture and General Revit Questions
    Last Post: November 11th, 2011, 01:48 PM
  5. Revit cannot play nice
    Last Post: October 7th, 2011, 02:46 PM
