Results 1 to 3 of 3
Thread: Family Types & Nested RFA
    Senior Member domsib's Avatar
    April 30, 2012
    586
    12:46 AM
    Can anyone help with a family issue I have?I have created an Air Terminal with 4 Family types. The Air Terminal can come complete with a Plenum Box on the top. I have created the Plenum Box family which also has 4 Family Types. I have loaded the Air Terminal into the Plenum Box Family. Is it possible to show nested Air Terminal Family Type A when Host Type A is selected, then when host Type B is shown nested Type B changes?At the moment whenever I change the Host family I cant find an option to change the nested family without overriding it in all types.
    April 12, 2011
    Chicago, IL
    523
    07:46 PM
    If the plenum box is shared and nested you can assign a family type parameter to it, and then set that for each air terminal type.
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    2,962
    07:46 PM
    Here's another thread
    https://www.revitforum.org/architect...tml#post196345
    in which we discuss methods of assigning Family Parameters
  1. Replies: 0
    Last Post: March 16th, 2017, 03:15 AM
  2. Nested Family Location Shifting When Changing Types
    By cellophane in forum Architecture - Family Creation
    Last Post: December 11th, 2015, 07:18 PM
  3. Replies: 5
    Last Post: April 2nd, 2014, 07:59 PM
  4. Window Types - Shared / Nested
    Last Post: March 18th, 2013, 04:30 PM
  5. Family Types and Nested Familes
    Last Post: June 6th, 2012, 02:58 PM
