Results 1 to 5 of 5
Like Tree2Likes
  • 1 Post By mdradvies
  • 1 Post By elton williams
Thread: wall panel sweeps
    Gold Coast
    2,626
    01:08 PM
    wall panel sweeps
    I have added a 1 metre x 20mm timber wall panel sweep to my existing interior walls. All is working well except when i get to the end of a wall section, as indicated in the image. Within the wall properties 'edit structure' dialogue, am I missing a 'wrap' option for the sweep right in front of my eyes or do I need to create a unique wall layer to place on each exposed end?
    If the picture looks wierd it's because there's no floor
    Attached Thumbnails Attached Thumbnails wall panel sweeps-timber-wall-panels.jpg
    Last edited by Munkholm; September 9th, 2011 at 10:24 PM. Reason: Fixed attachment
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,551
    03:08 AM
    No and no...
    You're not missing the "wrap sweep" option.
    But you also don't need to create an extra wall. Select the sweep in 3D and it will give you the option to change the return and after that align it to any face you want. See attached
    Attached Thumbnails Attached Thumbnails wall panel sweeps-wall-sweep-end-1.png   wall panel sweeps-wall-sweep-end-2.png
    Alex Cunningham likes this.
    Gold Coast
    2,626
    01:08 PM
    Thanks Martijn!!
    October 27, 2011
    1
    04:08 AM
    ....So i modified my wall sweep and it wraps into the window (negge). but I have a facade which is 80m long with many windows which all need this sweep modification. is there a way to make a small piece this way and then copy it to multiple floors and windows. if I do this; copy it to the level above it loses its modifications. is the a way to make mantain this sweep when I copy it?
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,551
    03:08 AM
    Hi Lennart, welcome to the forum. You're Dutch I presume?
    Anyway, with this amount of sweeps you'd probably be better of building a wall/face based, Line Based Generic Model. It's fairly easy to make such a family to have all kinds of parametric endings.
  1. scheduling wall sweeps by room
    By jameshs in forum Architecture and General Revit Questions
    Last Post: August 3rd, 2015, 09:43 AM
  2. Curtain Wall Panel Tags
    By kipsmiks in forum Architecture and General Revit Questions
    Last Post: June 29th, 2011, 02:15 PM
  3. Wall Sweeps Missing Endpoints for adjusting
    By sdbrownaia in forum Architecture and General Revit Questions
    Last Post: April 12th, 2011, 05:19 PM
  4. Wall Sweeps , Parapets and how to tag them.
    By drafterjohn in forum Architecture and General Revit Questions
    Last Post: January 13th, 2011, 01:52 AM
