Page 1 of 2 12 LastLast
Results 1 to 10 of 19
Like Tree3Likes
Thread: Doors not cutting the walls on certain parts.
    October 4, 2017
    70
    03:06 AM
    Hi Guys, I am coming with another problem. My Doors are not cutting the walls on certain places. I played with view range but still the same issue.
    Attached Thumbnails Attached Thumbnails Doors not cutting the walls on certain parts.-capture77777.png
    June 21, 2012
    Tours, France
    796
    05:06 AM
    Hi, I'm figuring out that we are talking about the same door family, am I right?
    if yes, you need to check the level parameter if you have intermediate levels in your project, if for a reason you had split the wall that may cause that too.
    if was you that model the door you may need to check if the void is cutting walls with have the size you are having troubles,
    Can you upload that door to see what's happening?, regards
    RevitCrazy likes this.
    October 4, 2017
    70
    03:06 AM
    actually the same door, mirrored one from a point to b , ''a'' door is cutting ''b'' is not cutting.
    It is the same door family from Revit.
    Attached Files Attached Files
    June 21, 2012
    Tours, France
    796
    05:06 AM
    Please give the sizes of the walls and all the data you think will be useful to try to re create the issue, regards
    October 4, 2017
    70
    03:06 AM
    sizes of the walls are 200 and 400 mm height of the door is 3200 mm , floor is two layer a) 200 mm b) 150 mm and level 0 is put after 200 mm.
    June 21, 2012
    Tours, France
    796
    05:06 AM
    Hi again, I've changed the height for your door and mirrored it and I got this (see pic), are you sure that height is not the problem?, regards
    Attached Thumbnails Attached Thumbnails Doors not cutting the walls on certain parts.-door.png
    June 21, 2012
    Tours, France
    796
    05:06 AM
    If is not a problem for you, send me your model I'll check it
    October 4, 2017
    70
    03:06 AM
    My level 1 is at 3900mm , my door is 3200 mm , i check the section everything looks fine except the plan view.
    Attached Thumbnails Attached Thumbnails Doors not cutting the walls on certain parts.-door-issue.png
    June 21, 2012
    Tours, France
    796
    05:06 AM
    ok, so height is not the problem , I've already check the family and all looks good , the walls where the door cut are the same for those which the doors seems not work?, I'm thinking that maybe the answer is much more easy, did you try to erase and re create the door? , it may sounds fool but it can works
    June 21, 2012
    Tours, France
    796
    05:06 AM
    Quote Originally Posted by RevitCrazy View Post
    Ah, I find it!!; the 200 mm of your door are the problem, once I've changed here the door stops cutting the wall , so you may need to create a plan view and change the section plane for that part of your drawing, am I clear enough?, regards
    Attached Thumbnails Attached Thumbnails Doors not cutting the walls on certain parts.-door-2.png
  1. Large doors, Not cutting windows properly in model.
    By Sasserfrats in forum Architecture and General Revit Questions
    Last Post: November 17th, 2017, 02:14 PM
  2. Large doors, Not cutting windows properly in model.
    By Sasserfrats in forum Out There
    Last Post: October 4th, 2017, 04:28 PM
  3. windows adn doors not cutting wall
    By ob37 in forum Architecture and General Revit Questions
    Last Post: February 6th, 2014, 03:54 PM
  4. Joined walls and Doors- doors with different expected width
    By Hugo Tavares in forum Architecture and General Revit Questions
    Last Post: May 8th, 2012, 05:39 PM
  5. Cutting parts from panels.
    By madhaka in forum Architecture - Family Creation
    Last Post: April 14th, 2012, 09:02 AM
