Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Like Tree3Likes
Thread: Doors not cutting the walls on certain parts.
  1.    #11
    October 4, 2017
    65
    11:36 PM
    ok, so height is not the problem , I've already check the family and all looks good , the walls where the door cut are the same for those which the doors seems not work?, I'm thinking that maybe the answer is much more easy, did you try to erase and re create the door? , it may sounds fool but it can works
    i wish i could send the model, Manager does not allow me to do so, But i did try to erase and put it back again, the same problem. . I restarted the pc the same problem
  2.    #12
    October 4, 2017
    65
    11:36 PM
    Ah, I find it!!; the 200 mm of your door are the problem, once I've changed here the door stops cutting the wall , so you may need to create a plan view and change the section plane for that part of your drawing, am I clear enough?, regards
    can u be a little more specific please? , actually why some of them cutting and very next one is not? its strange, is not it?
  3.    #13
    June 21, 2012
    Tours, France
    546
    12:36 AM
    Hi again Revitcrazy,
    You have the possibility to change the cut plan in a specific zone of your drawing by using the View Plan tool located View>Plan View, please see images, that allows you to change you cut plane in a specific area of your drawing without change the rest of the drawing, that may help you to override the graphics for your drawing, hope this helps regards
    Attached Thumbnails Attached Thumbnails Doors not cutting the walls on certain parts.-door-3.png   Doors not cutting the walls on certain parts.-door-4.png   Doors not cutting the walls on certain parts.-door-5.png   Doors not cutting the walls on certain parts.-door-6.png   Doors not cutting the walls on certain parts.-door-7.png
    RevitCrazy likes this.
  4.    #14
    October 4, 2017
    65
    11:36 PM
    Not working Andres.
  5.    #15
    June 21, 2012
    Tours, France
    546
    12:36 AM
    mmm, well without having the possibility to check the model is hard to say , the door family seems to work fine , so you need to check other elements like walls, floors and even the cut plane of your view, did you already try to use another door?, if yes did you have the same result?, I'll try to think in another solution, but is quite tricky your issue, regards
  6.    #16
    Member Damo's Avatar
    March 2, 2011
    London, UK
    124
    11:36 PM
    Phases?
    You haven't copied the door in a different Phase.
  7.    #17
    June 21, 2012
    Tours, France
    546
    12:36 AM
    Quote Originally Posted by Damo View Post
    Phases?
    Yes!!! that counts too!!, I just assumed that he was working in a project without phases , thanks
  8.    #18
    October 4, 2017
    65
    11:36 PM
    it is the first time i have heard the terminology called phases
  9.    #19
    June 21, 2012
    Tours, France
    546
    12:36 AM
    Quote Originally Posted by RevitCrazy View Post
    I will bet you that you'll hear about phasing in the near future and you will work with!!!
  1. Large doors, Not cutting windows properly in model.
    By Sasserfrats in forum Architecture and General Revit Questions
    Last Post: November 17th, 2017, 02:14 PM
  2. Large doors, Not cutting windows properly in model.
    By Sasserfrats in forum Out There
    Last Post: October 4th, 2017, 04:28 PM
  3. windows adn doors not cutting wall
    By ob37 in forum Architecture and General Revit Questions
    Last Post: February 6th, 2014, 03:54 PM
  4. Joined walls and Doors- doors with different expected width
    By Hugo Tavares in forum Architecture and General Revit Questions
    Last Post: May 8th, 2012, 05:39 PM
  5. Cutting parts from panels.
    By madhaka in forum Architecture - Family Creation
    Last Post: April 14th, 2012, 09:02 AM
