Results 1 to 10 of 10
Like Tree6Likes
  • 1 Post By snowyweston
  • 2 Post By snowyweston
  • 3 Post By JeffH
Thread: Sketchy Lines in One Model Only
    Member TFuller's Avatar
    March 7, 2014
    Evansville, IN
    326
    04:21 PM
    Question Sketchy Lines in One Model Only
    Has anyone found a way to get sketchy lines in just their own model and not the linked models?
    December 21, 2010
    C.LONDON
    4,274
    10:21 PM
    Afraid I've only turned it on (then off) once.
    One predicts view-stacking.
    TFuller likes this.
    Autodesk JeffH's Avatar
    December 13, 2010
    The Ivory Tower (Manchester NH)
    749
    05:21 PM
    Sketchy lines is an "all or nothing" setting for each view. The suggesting of view stacking or compositing outside of Revit would be the only real solution for what you are asking.
    March 7, 2014
    Evansville, IN
    326
    04:21 PM
    Thank you Snowy and Jeff for your feedback. For 30% documents, I can't bring myself to not use Revit but my fittings are not set up well for coarse detail. Using sketchy for the MEP model, but standard for the linked arch model would solve my issue somewhat, but I'm not going to duplicate all my enlarged plans for this purpose.
    As is common in many of these threads, the real issue is something entirely different and I'm trying to make people happy given their misunderstandings.
    July 10, 2015
    Boise, Idaho
    516
    03:21 PM
    Can you give us a reason for using sketchy lines for MEP?
    March 7, 2014
    Evansville, IN
    326
    04:21 PM
    The PM/scope deliverable wanted one-line hand sketches. I'm faster and more nimble using Revit than hand sketching. Even at 30%, I think I can give a better product using Revit with more consistent data management for design (aka keep track of stuff).
    There was concern over looking "too good" or something at 30%. Coarse detail could maybe have somewhat satisfied that, but as I mentioned, the fittings' coarse detail linework is not quite up to "good drafting practice" for single-line hand sketches. Therefore, proverbial rock and hard place.
    I played with the sketchy line detail to consider making my work look less ...good(?)
    I say let it eat, it looks good, let's move on. In a nutshell, I wanted my work to look 30%-ish. However, anyone that's done MEP knows that for a 30% construction estimate, you practically have to do 75% of your job. Same old story, different day, new attempt at dealing with it.
    December 21, 2010
    C.LONDON
    4,274
    10:21 PM
    Quote Originally Posted by TFuller View Post
    Model it Revit, print it, trace it by hand, scan it, print that draft, spill some coffee on it then fax it to the PM with "I trust this is the kind of thing you were after?"...
    Then follow that with the first (Revit) output and "But just in case not, here's something else that I think could work, which by the way took me considerably less time to produce"
    Asking/expecting less fidelity? WOW. #IfOnly.
    DaveP and cganiere like this.
    March 7, 2014
    Evansville, IN
    326
    04:21 PM
    Ha! I actually considered something along those lines...
    December 13, 2010
    749
    05:21 PM
    Back in the days of pen plotters we would put the pen in "loose" so it would wobble as it plotted.
    Member PatrickGSR94's Avatar
    July 7, 2017
    Hernando, MS
    339
    04:21 PM
    Might open their eyes if he sent a bill for the full amount of time spent doing that 2-step approach, but with a note saying "if I had done it in Revit only, it would be this (lower) amount".
  1. convert model lines to room separation lines
    By Ning Zhou in forum Architecture and General Revit Questions
    Last Post: May 2nd, 2016, 09:31 AM
  2. Replies: 0
    Last Post: June 24th, 2014, 12:15 PM
  3. Revit Learning Club: Sketchy Lines In Revit 2015
    By Revit Learning Club in forum Blog Feeds
    Last Post: May 26th, 2014, 09:15 PM
  4. David Light: Revit 2015 – sketchy lines
    By David Light Blog in forum Blog Feeds
    Last Post: April 6th, 2014, 10:45 AM
  5. Something Sketchy, but not in that way, just different
    By snowyweston in forum Hardware and Infrastructure
    Last Post: July 22nd, 2013, 10:16 PM
Tags for this Thread
