Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By elton williams
Thread: Spot Elevation Tags on the Facades.
    October 4, 2017
    70
    10:18 AM
    Hi Guys.
    There is a problem again i could not solve and it is about the spot elevations.
    How can i use spot elevation tags on my facades, I tried to cheat with lines, but unfortunately i cant use invisible line option when it comes to detail lines, there is no such an option actually. is there any alternative way to use spot elevations tool on facades
    Thank for your input in advance.
    Attached Thumbnails Attached Thumbnails Spot Elevation Tags on the Facades.-spot-elevation-tool.jpg
    October 4, 2017
    70
    10:18 AM
    Guys I found the the way to cheat, Thank you.
    Gold Coast
    2,266
    08:18 PM
    I sometimes use a really short detail line. I can hear you Reviteers shaking your heads in disgust...some of our projects have imported rhino facade parts and well, plenty of our rhino modellers/models are, ahem...inconsistent... that would be putting it nicely.
    Quote Originally Posted by RevitCrazy View Post
    It's good manners to provide an explanation when you answer your own questions!
    Jaime likes this.
    May 30, 2015
    169
    05:18 AM
    Hi Guys.
    Those look a lot like levels. What was the intent and as noted what was the solution.
    October 4, 2017
    70
    10:18 AM
    excuse me for replying late.
    What i did was to make a box with masking region tool with invisible lines and placing it under the elevation tag
    June 21, 2012
    Tours, France
    730
    12:18 PM
    LOL, I do the same as you Elton , sometimes a very short line can help to cheat Revit otherwise it may be a little annoying to find a point or a reference to certain annotation tools as Dimensions ans spot elevations
    October 4, 2017
    70
    10:18 AM
    Quote Originally Posted by Mengelmn View Post
    after putting the masking region box under the elevation tags i deleted the detail/reference lines and put the tags again on top of the invisible masking region box .
    Attached Thumbnails Attached Thumbnails Spot Elevation Tags on the Facades.-capture2222.jpg
  1. Override Project Units for Level Tags and Spot Elevations
    By tidalwave1 in forum Architecture and General Revit Questions
    Last Post: March 14th, 2016, 01:04 PM
  2. Spot Elevation
    By leetecture in forum Architecture and General Revit Questions
    Last Post: October 9th, 2015, 03:01 PM
  3. Replies: 0
    Last Post: July 3rd, 2015, 11:50 AM
  4. Spot elevation in a Box
    By lucis29 in forum Architecture and General Revit Questions
    Last Post: October 11th, 2012, 02:01 PM
  5. Elevation Tags - Reference view & Elevation in one tag?
    Last Post: January 10th, 2012, 09:17 PM
