Donate Now Goal amount for this year: 3000 USD, Received: 2285 USD (76%)
Results 1 to 4 of 4
Thread: Bulk Reload Families to Set Correct Library Path
    December 21, 2010
    Phoenix, AZ
    2,159
    03:03 PM
    Which tool does this?
    I've tried Revit Express Tools, Family Loader but it's not resetting the path to the file as I thought it would.
    I thought I remember hearing about one that would but I don't recall which one it was.
    Thanks.
    Gold Coast
    2,193
    08:03 AM
    Can you just drag them in from explorer? Might get a lot of "do you wish to replace" buttons though.
    (Sorry, saturday morning hangover shenaningans )
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    5,701
    06:03 PM
    Unless I'm way off base - Family Loader will do it but you need to load the families from the correct path and 'Load' them, instead of just using the Reload.
    KiwiCodes BonusTools also has (or did have) a family loader / reloader and you can modify the path prior to reloading.
    December 21, 2010
    Phoenix, AZ
    2,159
    03:03 PM
    Unless I'm way off base - Family Loader will do it.
    Got it to work but had to first open each RFA, change something, and save it back so Revit saw it as a new family. Apparently, just moving it to a different folder isn't enough of a change for the Big R!
    Luckily, DynamoAutomation works fairly well for this (though it stops after 80 or so I have to restart the computer to continue).
  1. Lost material library path
    By Andres Franco in forum Architecture and General Revit Questions
    Last Post: September 6th, 2017, 07:45 AM
  2. Change saved path of Revit links in bulk?
    By wwdreamb in forum MEP - General
    Last Post: November 16th, 2016, 06:21 PM
  3. Managing families in library
    By DavidLarson in forum Architecture and General Revit Questions
    Last Post: December 14th, 2015, 02:56 PM
  4. Useful Families to add to the library?
    Last Post: April 2nd, 2013, 07:58 PM
  5. Family Duplication and Eradicating Similarly Named Families from your Library
    By Alex Cunningham in forum Tutorials, Tips & Tricks
    Last Post: February 7th, 2013, 03:51 AM
