Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By Charles Karl
Thread: Moving Walls
    September 13, 2017
    2
    02:36 PM
    Question Moving Walls
    I have a project that has been completed and now I am reworking it. One of the things I need to do is expand the hallways from 4' to 6'. However, when I select the wall I would like to move, the permanent dimensions associated with the wall do not allow me to edit them in order to move the wall. I cannot figure out why this is happening.
    Any ideas?
    Thanks in Advance!
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    5,771
    04:36 PM
    is there an Activate Dimensions button in your options bar? if so, click that and you can modify them.
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    2,537
    03:36 PM
    There's probably a Lock somewhere.
    Either that Wall is Aligned and Locked to something else (another Wall or a Grid) or there's a Dimension with a Lock on it.
    First select the Wall you want to move and look around at the Temporary Dimensions that show up. See if any of them have a closed Lock icon.
    If you don't see anything there, click on the "Reveal Constraints" icon at the bottom of the drawing window. That should show you in maroon anything the Wall is constrained to. Unlock any closed Lock icons you see.
    In general, you're going to get in trouble if you start Locking elements in a model. The motto in our office is "Locks are for Families, not Projects"
    It may seem like a good idea at first, but you're pretty much guaranteed to run into the kind of problems you're seeing once you start locking down Walls.
    September 13, 2017
    2
    02:36 PM
    That would do the trick. Thank you!
    Is there a setting in the wall type that causes me to have to click "Activate Dimensions"?
    March 21, 2013
    Phoenix, AZ
    238
    01:36 PM
    My guess is that the dimension is attached to something that is co-planar with the wall, but not the wall itself (floor edge maybe?). In these cases, I'll re-dimension, but pay more attention to what item is identified on the status bar before setting my dimension.
    Senior Member Charles Karl's Avatar
    December 6, 2011
    Fairbanks, Alaska
    916
    12:36 PM
    Quote Originally Posted by badam View Post
    Any ideas?
    Thanks in Advance!
    Check to see if the wall is pinned. If it is, you cannot drive the wall with the dimension.
    cganiere likes this.
  1. Load bearing Masonry Project - Walls over Hidden, Walls Under Solid?
    By Damenk in forum Structure - General Questions
    Last Post: July 6th, 2015, 07:30 PM
  2. Brick walls + wrapping plaster, THEN partition walls (gypsum boards with metal const)
    By turuly in forum Architecture and General Revit Questions
    Last Post: July 21st, 2014, 06:44 PM
  3. moving walls independently
    By ekkonap in forum Tutorials, Tips & Tricks
    Last Post: March 4th, 2014, 11:40 PM
  4. Moving walls!
    By byork in forum Architecture and General Revit Questions
    Last Post: October 22nd, 2012, 04:02 PM
  5. Replies: 0
    Last Post: January 26th, 2012, 03:15 PM
