Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Thread: Setting view range for a Plan Region
    July 24, 2017
    12
    04:09 AM
    Hi All
    i got stuck with adjusting view range in Revit for Plan region.
    what i need is as follows
    1: I have a second floor plan from an 8 storied building,
    2:i want to show second floor plan plus what ever is outside building as landscape on ground floor and first floor.
    i am attaching a pic to illustrate.
    I am using revit 2017.
    Please help to solve this issue, or advise any work around for this.
    Attached Thumbnails Attached Thumbnails Setting view range for a Plan Region-view-range-issue.png
    Senior Member
    December 16, 2010
    702
    02:09 PM
    if you are using an architectural discipline view you can set (in the view properties) a background to your view.
    So you can "underlay" the landscape plan and overlay the other to your plan.
    Attached Thumbnails Attached Thumbnails Setting view range for a Plan Region-backfore.png
    Gold Coast
    2,147
    02:09 PM
    Set your plan region view depth to ground floor.
    July 24, 2017
    12
    04:09 AM
    Quote Originally Posted by Karalon10 View Post
    Hi
    Thank you , a bit more to ask you if you dont mind.
    your suggestion solved my problem about 50%
    please find the attached pics, in second condition pic, i cant see the level4 furniture, if i make underlay top until 5th level, then i am seeing the internal walls that i should not show in drawing, bcs it is level 4 internal wall.
    Attached Thumbnails Attached Thumbnails Setting view range for a Plan Region-condition-01.png   Setting view range for a Plan Region-condition-02.png
    July 24, 2017
    12
    04:09 AM
    Yes, that is good idea.
    but how to set a separate view template for the view in plan region, bcs i want that view in in light color like underlay.,
    But plan region has another problem, if it touches a slab on one edge, then all of its parts in other area (even out side plan region) shows.
    Gold Coast
    2,147
    02:09 PM
    Quote Originally Posted by zakazai View Post
    Yes the touching elements thing is really annoying. You could also create a separate view for the levels below (with whatever view template if desired) and then overlay both plans on the sheet.
    July 24, 2017
    12
    04:09 AM
    yeah that is great. i will try it.
    thank u
    July 24, 2017
    12
    04:09 AM
    So at last what i did is like this
    for the 5 storied building as i posted in the picture.
    and i am on 5th floor plan, i used underlay option from level one to level 4, then for level 4 to level 5 i used a plan region,
    and for my level 5 plan is a normal view range settings. and i selected all elements in plan region and changed its properties to half tone as view override.
    that is ok for me until now.
    July 24, 2017
    12
    04:09 AM
    HI
    One last quostion please
    See the image,
    I have made this with view range settings as shown in pic.
    but one issue, i want to present it in shaded mode.
    so how i can make the beyond zone shadings as half tone.(not line weight, but shading color of materials).
    i want only my floor plan be bright in shaded color.
    Any suggestion from anyone please.
    Attached Thumbnails Attached Thumbnails Setting view range for a Plan Region-1.png
    Gold Coast
    2,147
    02:09 PM
    The good old 50% transparent masking region will do it.
    But you didnt hear that from me.
    If you did the overlaid views you could simply set everything to 50% in your lower levels views.
    One other thing not mentioned yet is in a single view set your view range base at level base (default setting) and set the view depth to infinite or at least groind floor, cant remember if this sets lower levels to lighter or not and ive left work for the night
  1. View Range for Roof Plan
    By MDeaks in forum Architecture and General Revit Questions
    Last Post: June 22nd, 2016, 09:54 PM
  2. View Range Exceptions of Plan View
    By Pentapolis in forum Architecture and General Revit Questions
    Last Post: January 16th, 2016, 10:19 AM
  3. Plan Region View Range ignores Linked Files?
    By kescr in forum Architecture and General Revit Questions
    Last Post: May 13th, 2015, 03:18 PM
  4. Plan view range
    By thierry29 in forum Structure - General Questions
    Last Post: July 19th, 2013, 06:46 PM
