Results 1 to 6 of 6
Thread: Filter Rules for Removing Sections Not on Current Sheet
    April 30, 2015
    Michigan
    109
    04:34 PM
    Is there a way to filter sections not on the current sheet. I always have issues removing sections from adjacent floors. It would be nice if I could have the following filter rule:
    Sheet Number
    does not equal
    "current sheet"
    Can Revit have non specific stuff in the last field? This way it would work well with a template.
    January 19, 2012
    202
    03:34 PM
    You could either create a Section Type or add a view parameter to filter with, or Hide at scale coarser than, or play with different filter definitions (ends with, for example)...
    Coeur d Alene, ID
    4,278
    01:34 PM
    Sections will show on whatever levels the section is cutting. So if you don't want a section to show on a floor then adjust the crop region so it doesn't go through that level.
    April 30, 2015
    Michigan
    109
    04:34 PM
    Sections look bad when you don't have context of the floor and structure above.
    9,070
    03:34 PM
    Then get ready to do some manual hiding, or adding in some manual parameters, to tell the Filter what level you want it to be visible in.
    The *Section* doesnt live in the Sheet. It lives in the model, and may extend to a variety of plans, based on levels, view ranges, plan regions, and so on. So the section wont REALLY be able to tell what sheet you are looking at.
    I havent tried to see if you can ASK a section what view it shows up in, and what sheet the view is on, in Dynamo. But even if you can, i wouldnt trust it, since sections can show in many many views. Id just assume manually do it. Or, you know, come up with a different system.
    October 14, 2011
    Boston, MA
    208
    03:34 PM
    I've dealt with this same issue and I ended up creating a new Section Type for each floor, for example
    Building Sections: First Floor
    Building Sections: Second Floor
    then I used Rule-Based filters within my view templates to choose which sections I want to be visible. This means you'll probably need more view templates than you would have normally..I have found that it's easy to stay on top of.
  1. Sheet Current Revision
    By Vanguard in forum Architecture and General Revit Questions
    Last Post: July 13th, 2017, 09:54 PM
  2. Filter Rules
    By andyrh1982 in forum Architecture and General Revit Questions
    Last Post: October 6th, 2016, 02:34 PM
  3. Removing Sub Disciplines
    By domsib in forum MEP - General
    Last Post: January 30th, 2015, 01:50 PM
  4. Filter Add View To Sheet drop down list?
    Last Post: July 30th, 2012, 04:52 PM
  5. Drafting View Sections VS Building Sections
    Last Post: February 21st, 2011, 04:57 PM
