Results 1 to 2 of 2
Thread: Adding Parameter -Cylinder
    September 23, 2014
    45
    01:08 AM
    I am trying to add a parameter-diameter to a cylinder and it does not work.
    In Type Properties I have got a parameter Diameter and when I type a value, it does not change a typed diameter.
    What Am I doing wrong?
    I am adding a dimension for diameter and a Label for a Parameter Properties, when I save it - it does not work?
    July 7, 2011
    Rotterdam, Holland
    1,228
    03:08 AM
    I'd say, make an extrusion and label the outline with the radius.
    If you really need the diameter parameter, just make that and add a formula to the radius parameter =diameter/2
  1. Drawing sheet/table/Scale-adding a parameter
    By peterweaver in forum Architecture and General Revit Questions
    Last Post: June 23rd, 2017, 07:45 AM
  2. Adding Parameter to Lighting Fixture Tag
    By andyrh1982 in forum Architecture and General Revit Questions
    Last Post: July 15th, 2016, 09:23 AM
  3. Adding a Project Parameter (2014)
    By Joshua Kohl in forum Architecture and General Revit Questions
    Last Post: August 21st, 2014, 11:28 PM
  4. Adding a family parameter via the api
    By KRedman in forum Third party Add-Ins, API and R&D
    Last Post: November 4th, 2013, 01:56 PM
  5. adding pen style parameter to filled region
    By hommes77 in forum Architecture and General Revit Questions
    Last Post: June 11th, 2013, 08:08 PM
