Results 1 to 3 of 3
Like Tree2Likes
  • 2 Post By Twiceroadsfool
Thread: Adjusting Line Weight for Window Sill
    July 24, 2017
    12
    09:33 AM
    Hi All
    I would like to make a view template for printing floor plans
    and i want to see the windows lighter, i dont want to see wall line in window area.
    please find attached pic, i want to make a set up as per red marking zone, but what i have is like under blue marking.
    and i have a lot of windows, it is not one wall to make manual workaround.
    any idea please
    Attached Thumbnails Attached Thumbnails Adjusting Line Weight for Window Sill-sd.png
    9,178
    04:33 AM
    You need to edit your lineweight for Walls in Projection, is my guess.
    Manage Ribbon > Object Styles > Model Elements > Walls- What is the CUT lineweight versus the PROJECTION line weight?
    cganiere and zakazai like this.
    July 24, 2017
    12
    09:33 AM
    Yes,
    Thank you
  1. Window Sill Problem
    By Marcieszyn in forum Architecture and General Revit Questions
    Last Post: June 20th, 2017, 03:06 PM
  2. Window line weight
    By Ji Gantor in forum Architecture and General Revit Questions
    Last Post: July 17th, 2014, 11:15 AM
  3. Window sill for curtain wall
    By boriskam1991 in forum Architecture and General Revit Questions
    Last Post: May 27th, 2013, 10:13 PM
  4. Window sill & Head detail
    By EddyRevit in forum Architecture and General Revit Questions
    Last Post: September 24th, 2012, 07:20 PM
  5. Window Sill elevation visibility issue
    By HenryD in forum Architecture and General Revit Questions
    Last Post: August 9th, 2011, 12:04 PM
