Results 1 to 7 of 7
Like Tree2Likes
  • 1 Post By PatrickGSR94
  • 1 Post By MPwuzhere
Thread: Revit Video Card
    August 5, 2017
    2
    08:46 AM
    Revit Video Card
    Hello, if someone could please help me with this issue I am having would be greatly appreciated. I just bought a laptop and installed revit 2018 and noticed something wrong with the graphics. Whenever I zoom into a wall in plan view or any lines, the drawing goes blank and I cant see anything. Also, in 3d when I rotate the model, the building goes blank except the glass. When I click on options / graphics it says unknown Video card and the following message:
    The installed video card 'NVIDIA GeForce 940MX' has not been tested with Revit.
    You may continue to use Hardware Acceleration.
    If you experience graphics display issues, you should:
    - Turn off Hardware Acceleration
    If I turn off hardware acceleration, revit becomes slow. I recently installed the latest driver for the video card so could this be an issue. Please let me know of any possible solutions as working like this can get very frustrating.
    Thanks in advance!
    Carlos
    Member PatrickGSR94's Avatar
    July 7, 2017
    Hernando, MS
    446
    07:46 AM
    Try updating the driver from nVIDIA.
    February 22, 2013
    317
    08:46 AM
    From what I've read, gaming graphics cards are usually not the best for Revit.
    July 7, 2017
    Hernando, MS
    446
    07:46 AM
    Quote Originally Posted by Necro99 View Post
    Nonsense. I use a custom-built rig with a GTX 960 graphics card and it works amazingly well. In my experience in the last several years, I've found nVIDIA GeForce GTX cards in general work great with Revit, while Quadro graphics cards don't offer much more benefit at all, so they end up being more of a waste of money.
    If you're doing video editing and high end animation rendering, like with 3DS MAX, then a Quadro card might make sense. But for Revit it's not really necessary.
    But, I have also found that updating drivers can alleviate some graphical issues that come up every now and then.
    Dave Jones likes this.
    Coeur d Alene, ID
    4,736
    05:46 AM
    Ha...must have been an Autodesk Whitepaper... They are great with Revit as they are made for 3D. Actually, it is the GTX cards that work great. The MX cards will work, but they are not as great as GTX cards. So you probably will want to disable hardware acceleration.
    Also, make sure that the 940MX card is the "Dedicated Card" in the graphics display settings for all programs, as your system more than likely has an Intel card on it too.
    PatrickGSR94 likes this.
    August 5, 2017
    2
    08:46 AM
    Thank you guys for your responses. I actually got it to work again. I uninstalled the latest NVIDIA graphic display driver which seemed to be the cause of the problem.
    10,098
    07:46 AM
    There is a long history of the latest graphics card driver not necessarily being the best one for running in Revit. Sometimes you do need a newer driver, and sometimes you need an older driver. I recommend keeping a list of video cards that are in the office, and which drivers work the best with Revit. Then telling everyone not to change them without good reason.
    Michael is right that if the card is not sufficient, turning off Hardware acceleration may be the only Avenue to make Revit stable. Having said that, I would literally buy a new computer before I would run Revit with Hardware acceleration turned off.
    Aaron Maller
    Director
    Parallax Team, Inc.
  1. NVIDIA Quadro M2000M Video Card and Rendering in Revit 2016
    By mblacklock in forum Architecture and General Revit Questions
    Last Post: October 19th, 2016, 06:34 PM
  2. Awesome Laptop....Revit hates the video card!
    By MPwuzhere in forum Hardware and Infrastructure
    Last Post: October 24th, 2012, 06:02 PM
  3. Video Card
    Last Post: August 1st, 2012, 12:15 AM
  4. Revit and Video Card with Display Ports
    By dzatto in forum Hardware and Infrastructure
    Last Post: June 5th, 2012, 09:06 PM
  5. Replies: 0
    Last Post: January 20th, 2012, 12:45 AM
