Results 1 to 4 of 4
Thread: global parameters
    March 14, 2016
    15
    02:03 AM
    global parameters
    I am trying to create a minimum room length where you can stretch the wall to minimum and there is no maximum. I try to create global parameter. When I check mark reporting parameter, I able to stretch but I can not fill in formula field. When I uncheck, look like both walls are lock. see attached. Please help. Thanks
    Attached Thumbnails Attached Thumbnails global parameters-global-parameter.jpg
    Member PatrickGSR94's Avatar
    July 7, 2017
    Hernando, MS
    195
    01:03 AM
    Reporting Parameters merely report what's in the model. They don't control anything. A regular Global Parameter will control whatever dimension you have set to that label. However I don't see how to make a global parameter set a minimum dimension size and still have it dynamically editable in the model. Maybe someone else knows?
    Senior Member Robin Deurloo's Avatar
    July 7, 2011
    Rotterdam, Holland
    682
    08:03 AM
    2 parameters
    Length
    Length_calc: IF (length < 1200; 1200; Length)
    Assuming you min. Length is 1200 mm
    Use the last one as your constraint.
    Use the first one to fill in the value
    Problem is you will always have to edit the dimensions in the global parameters. You can not move the wall in the project as that will break the constraint.
    Other then this I can not think of something right now
    Lurker
    September 4, 2017
    1
    12:03 AM
    I have another Global Parameter question. In my title block family I have yes/no parameters to control the visibility of several objects such as layout lines, professional seal, not for construction stamp, etc.. I have set up yes/no global parameters to match these and have linked them together. This allows me change one global parameter and prepare my sheets for printing. When I change the global parameter the local parameter changes IF they are directly linked one to one. However, if there is a formula between them such as "=and(global_parameter, instance_parameter)" the local instance parameter with the formula does not automatically change. If you manually go in and change the instantiate parameter in the formula off and back on the formula works. Any ideas as to why changing the global parameter dose not trigger the formulas?
  1. Height offset from level and Global Parameters
    By Cyus in forum Architecture and General Revit Questions
    Last Post: June 27th, 2016, 02:56 PM
  2. Global Parameters & Arrays
    Last Post: June 2nd, 2016, 02:32 AM
  3. How to use global parameters?
    By andreas2 in forum Architecture and General Revit Questions
    Last Post: December 20th, 2015, 09:58 PM
  4. R2 Global Parameters
    By ryntau in forum Architecture and General Revit Questions
    Last Post: December 18th, 2015, 02:26 PM
Tags for this Thread
