Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Like Tree4Likes
Thread: Nested Conditional statement
  1. #11
    Senior Member
    December 16, 2010
    684
    03:33 PM
    Quote Originally Posted by duende123 View Post
    First.
    You can not modify the value of a parameter using the parameter itself in the formula that modifies its value
    So we are going to have 2 different parameters.
    Angle (real value)
    ANGLE (fixed value)
    To the latter we assign the formula:
    if(Angle < 22.5░, 90░, if( Angle < 35░, 30░,if(Angle < 67.5░ , 45░, 90░ )))
    IF angle is less than 22.5░: ANGLE = 90░
    else
    IF angle is less than 35░: ANGLE = 30░
    else
    IF angle is less than 67.5 : ANGLE = 45░
    else
    ANGLE = 90░
    Yes that is exactly how I used it.
    But thanks for clarifying for the others that may read the post.
    Actually I just tested your formula out also - although it does work (as in Revit accepts it as valid)
    It is not correct for my needs, basically the minimum angle I can have is 30 degrees. I probably need to change the other formula down to 1 degree minimum.
    if(and(Angle > 1.5░, Angle < 35░), 30░, if(and(Angle > 35░, Angle < 67.5░), 45░, if(and(Angle > 67.5░, Angle < 90░), 90░, 0░)))
    Then in my schedule I can filter out any results that report 0 so they don't figure in my lists.
  2. #12
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    5,556
    12:33 AM
    Angle (real value)
    ANGLE (fixed value)
    just my $0.02: I would not create the additional parameter(s) just by capitalizing the name. Adding a descriptive suffix is a much better method in the long run. It will help you later when you need to go back and edit the family and it is more consistent on the user end of things.
    Angle
    AngleCalc
    Sidenote: When I'm working with longer formulas I will copy them into Notepad++. It has syntax highlighting so you can see where your expressions start & stop and make sure all of your parenthesis have a mate.
    Attached Thumbnails Attached Thumbnails Nested Conditional statement-notepadformula.png
    duende123 and Karalon10 like this.
  3. #13
    Member duende123's Avatar
    November 20, 2015
    140
    12:33 AM
    That's the cherry on the ice cream...
    or BEER
  4. #14
    November 23, 2012
    68
    10:33 PM
    I've never seen any resources from Adesk or anywhere else where this Revit formula system is described.
    I know Adesk documentation is horrible, but there's zero written down about this anywhere - It's bad even by Adesk's low standards. Am I missing something?
    Is there somewhere where this syntax is charted out and can be learned? Or is it all some standard coding syntax that is obvious to people who 'do code stuff'?
  5. #15
    Senior Member
    December 16, 2010
    684
    03:33 PM
    Quote Originally Posted by bt.comm View Post
    https://www.revitforum.org/tutorials...day-usage.html
    The above thread has the absolute basics outlined, although it does not describe WHY or the logic behind how things work but has some basic examples which I have used on several occasions as a basis or start point but usually it is when things go off this path that I get totally lost and come here for help.
    I did C++ programming WAY back in uni like 20 years ago (and I was never very good at that back then either) so yes there are a lot of similarities in the "logic" or what the computer expects to see. Essentially it is basic coding, but if you never did any basic coding then....you are out in the dark. I'm wondering if there are any good textbooks or resources around that someone can recommend for the basics?
  6. #16
    November 20, 2015
    140
    12:33 AM
    Karalon:
    Try this formula ...
    if(Angle < 1.5░, 0░, if(Angle < 35░, 30░, if(Angle < 67.5░, 45░, if(Angle < 90░, 90░, 0░))))
    Bt.comm:
    look here...
    https://www.augi.com/articles/detail/formulas-families
    Not everything, but to start is good.
    I help you with whatever you need
  1. Conditional IF statement
    By Karalon10 in forum Architecture and General Revit Questions
    Last Post: April 24th, 2017, 03:22 PM
  2. Yes/No Parameter in Conditional Statement
    By keithwales in forum Architecture and General Revit Questions
    Last Post: September 16th, 2014, 05:00 PM
  3. Conditional Statement question
    By BLothian in forum Architecture - Family Creation
    Last Post: May 15th, 2014, 03:34 PM
  4. Visibility Yes/No Conditional Statement
    By Lisa in forum Architecture - Family Creation
    Last Post: February 11th, 2014, 12:29 AM
  5. Conditional Statement Help
    By Kent in forum Architecture - Family Creation
    Last Post: February 12th, 2012, 10:07 PM
