Page 1 of 5 12345 LastLast
Results 1 to 10 of 41
Like Tree6Likes
Thread: Delete all Views and Sheets in model
    January 21, 2015
    10
    09:35 AM
    Hi all,
    Got to strip out all our views and sheets to give to a client. Just leaving one overall 3d view.
    Whats the quickest and most efficient way to do this please?
    Thanks
    May 4, 2011
    103
    05:35 AM
    etransmit for revit
    Member PatrickGSR94's Avatar
    July 7, 2017
    Hernando, MS
    266
    04:35 AM
    Shift-Select all views and sheets in the Project Browser and delete? Shouldn't need any 3rd party apps. Then Purge Unused, run 3 times to get everything.
    May 31, 2012
    Syracuse, NY
    177
    05:35 AM
    I tend to just have a schedule of views,sheets and even schedules sometimes
    Then delete rows and leave any that I may want to keep for what ever reason
    Then purge unused
    I've never actually used etransmit, do you have control over what that removes?
    Member duende123's Avatar
    November 20, 2015
    177
    05:35 AM
    Look at the possible options
    Attached Thumbnails Attached Thumbnails Delete all Views and Sheets in model-cleanup.jpg
    wgfletch likes this.
    May 31, 2012
    Syracuse, NY
    177
    05:35 AM
    good to know, just what I listed ha
    thanks Duende123
    July 7, 2017
    Hernando, MS
    266
    04:35 AM
    I don't understand this need for other 3rd party software. I just went to a new blank file, opened the default 3D view, Shift-Select all views in PB and then Ctrl-deselect the 3D view, then hit delete. All views gone. Shift-select all schedules, Legends, and sheets. Everything gone. Purge unused 3 times. It should take no more than 20-30 seconds, unless it's a big model and the purging takes awhile.
    November 20, 2015
    177
    05:35 AM
    The possibility of cleanup of the etransmit is not the reason why I use it.
    What I most appreciate is the redirect of the links.
    9,178
    04:35 AM
    Quote Originally Posted by PatrickGSR94 View Post
    If you have custom view types, you cant do it that way. Selecting the parent heading of the View Types makes it so you cant use the delete key, or right click > delete (the delete key only deletes view types that are already expanded when you select them). And frankly... If you DONT have Custom View Types, you are missing out on a TON of efficiency.
    You can use the "special shortcut keys" to auto-expand entire sections of the Project Browser, then scroll all the way through it to select everything, but its still a bunch more time.
    Frankly, i dont see a point in deleting them at all. But thats a debate thats been rehashed a billion times, in all forums and mediums, so i wont bother with that again. But my answer? Just dont delete them. Send that bad boy just how it is in your office.
    July 7, 2017
    Hernando, MS
    266
    04:35 AM
    I'm not sure if I follow. If I select the first Floor Plan view at the top of the PB, then shift-select the last Drafting View in the PB (or area plan or whatever is last), then ctrl-select my current view, I can delete everything with one press of the Delete key, even with the view type headings selected.
    Any links to suggestions for the PB? I'm always looking for ways to improve our template. Right now we just have the usual All Views or Not On Sheets, with headings for floor plans, ceiling plans, 3D views, elevations, sections, details, drafting views and area plans. Then legends, schedules, sheets, etc. Are you referring to custom view types such as separate elevation types for interior and exterior, with separate view templates? We definitely do things like that. But we don't do any type of special view sorting in the PB like by discipline, etc. because we're just architectural in this office.
  1. Case Design Inc Addins - Delete All Views, Sheets and Links.
    By ThatBIMGuy in forum Third party Add-Ins, API and R&D
    Last Post: June 5th, 2013, 11:46 PM
  2. Revit OpEd: Case App Delete Sheets Views and Links
    Last Post: May 20th, 2013, 03:15 PM
  3. Replies: 0
    Last Post: June 13th, 2012, 05:15 AM
  4. Revit OpEd: Delete Sheets In Browser or Schedules
    Last Post: April 25th, 2012, 04:15 PM
  5. Avoiding changes on sheets while working on the model or other views
    By eks_al in forum Structure - General Questions
    Last Post: January 12th, 2012, 02:57 PM
