Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 27
Like Tree3Likes
Thread: Door Handling - Left / Right Reporting
  1. #11
    9,070
    06:25 AM
    The mirror and Flip information is in their properties, if you look with Revit Snoop. The parameters are called FacingFlipped and HandFlipped.
    For whatever reason, you cant access them directly using GetParameterValueByName, as it just returns a null value. But a few people have made nodes that do it for you. And honestly, the Python to do it is simple enough that even i understand it (and i CANT write code). Because it LITERALLY just compares those two possible parameters, to generate the 4 possible outcomes (which, for my needs, is really only two different outcomes).
    So here is a crazy small graph that does it.
    Uses ONE custom node, from Archi-Lab Grimshaw.
    EDIT: To give Credit, Havard Vasshaug did this like... 3 years ago. And introduced me to a new (to me) band (that i now love) while doing it:
    https://vasshaug.net/2014/09/01/door...tion-in-revit/
    Attached Thumbnails Attached Thumbnails Door Handling - Left / Right Reporting-2017-07-13_10-55-17-door-handing.png
    cganiere likes this.
  2. #12
    jmk
    jmk is offline
    Forum Addict jmk's Avatar
    December 31, 2012
    NM, USA
    1,348
    05:25 AM
    Thanks, I've already tried that node in the same setup you show, but only get null values. I'll see if I can hack the python to just get the flip information out of the door.
  3. #13
    9,070
    06:25 AM
    Did you use the Phase Node, or try to use a Code Block to send text in with the correct phase name? The latter doesnt work.
  4. #14
    jmk
    jmk is offline
    December 31, 2012
    NM, USA
    1,348
    05:25 AM
    I used the select phase node. I can get a result if I copy the python script into the result and take out the bit of code relating to to_room.
    I next tried filtering the doors to those in the matching phase and fed them in, and it gives a result. At this point I don't trust the results, since for testing I had a series of doors each with a different combination of flip and mirror. All those doors (having no surrounding room) identified themselves as right or left hand reverse. Right and left hand doors with a to room were either left or right.
  5. #15
    December 21, 2010
    Phoenix, AZ
    2,210
    04:25 AM
    Isn't handing based on the secured side of a door?
    close - where you put the key - http://idighardware.com/2014/08/back...s-handing-101/ - so how does Revit in this workflow determine that?
  6. #16
    9,070
    06:25 AM
    Interesting. Well, there are multiple nodes that do it, i think. But that is a good point. I would remove any references to the To Room and From Room all together, as my doors behave really nasty with that stuff, lol.
  7. #17
    Member Bjorn_K's Avatar
    April 8, 2011
    Rotterdam, Netherlands
    234
    01:25 PM
    Quote Originally Posted by PatrickGSR94 View Post
    Know of any good Dynamo primers? I'd like to check it out but have absolutely no clue how it works.
    About | The Dynamo Primer
  8. #18
    November 2, 2011
    Slaithwaite ("Sla wit"), W Yorks, UK
    165
    12:25 PM
    Quote Originally Posted by GMcDowellJr View Post
    close - where you put the key - I Dig Hardware » Back-2-Basics: Handing 101 - so how does Revit in this workflow determine that?
    Wow! That is confusing. Logically, the secure side and secured side would be the same thing, surely? Take a corridor and a store room off the corridor. To me the corridor is the insecure side, and is where you would need to insert the key. The locked store room is the secure/secured side. Your naming is not how we are used to doing things in the UK, but I discovered a long time ago that how LH/RH is defined varies not only by location (country), but by ironmongery supplier (presumably dependent in which country the company originates). Rather than use LH/RH I always use CW/ACW clockwise opening/anti-clockwise opening direction and then specify hardware as fixed to the opening face or to the closing face as appropriate. That was following guidance from one of the largest hardware suppliers here and I've stuck to that ever since.
  9. #19
    jmk
    jmk is offline
    December 31, 2012
    NM, USA
    1,348
    05:25 AM
    Quote Originally Posted by john.warburton View Post
    Interesting to see how it varies. How would you determine from which direction you view the swing?
    As to scripting it, the right/left would be determined by based on how the doors are modeled, and then how they have been flipped/mirrored. My intent on the secured side was to combine that information with the location of a shared hardware family.
  10. #20
    December 21, 2010
    Phoenix, AZ
    2,210
    04:25 AM
    I always thought of it as the side from which it was secured - meaning, the side that you would use a key on should you lock the door. The edit I made in the post reflected that clarification based on the website I linked.
    I suspect that the company you're referring to told you CW/ACW to make your life easier but that they still look to see which side is keyed/secured/whatever when they're helping select hardware. You have to know this added bit to choose hardware sets. No getting around it.
    Quote Originally Posted by jmk View Post
    You might find this more trouble than you'd expect. The core of a lockset can be on either side of a door.
  1. Shades of Grey: LEFT-RIGHT, LEFT-RIGHT
    By Shades of Grey in forum Blog Feeds
    Last Post: January 24th, 2016, 04:16 PM
  2. Problem with Door parameters reporting room name/ number
    By cadmancan in forum Architecture and General Revit Questions
    Last Post: June 3rd, 2013, 10:44 PM
  3. Door Handing Handling
    By Cyus in forum Architecture and General Revit Questions
    Last Post: January 14th, 2013, 08:37 AM
  4. TAB key for left handed?
    By jbenoit44 in forum Hardware and Infrastructure
    Last Post: November 21st, 2011, 11:20 AM
  5. Curtain Wall Door reporting incorrect level
    By rkitect in forum Architecture and General Revit Questions
    Last Post: May 19th, 2011, 09:10 PM
