Page 1 of 4 1234 LastLast
Results 1 to 10 of 31
Like Tree8Likes
Thread: Cancel Editing Text Grrrr!
    "I am NOT a Revit tutor!"
    Dave Jones's Avatar
    4,122
    06:18 PM
    I've been working on my first R2017 project for the last few days and the dialog that pops up when I finish creating text is driving me nuts . Create text, done, Escape, left click with the mouse, another create text box pops up, if you then hit Escape again the "Do you want to keep changes in your text note? dialog pops up. One either needs to hit Escape twice or use the Modify button Way Up There At the Left Top. Can't get out of it with another Escape, one must manually click on Yes, No, or Cancel. I fully understand why some might find this useful but I find it annoying. When I'm done, I'm done, leave me alone! Is there any way in the .ini to turn this off??
    iru69 likes this.
    Coeur d Alene, ID
    4,188
    06:18 PM
    um...yeah.
    Member koolair's Avatar
    July 31, 2014
    180
    09:18 PM
    Quote Originally Posted by Dave Jones View Post
    Did you download the service pack? Im on Revit 2017.2 and not seeing that.
    Dave Jones's Avatar
    4,122
    06:18 PM
    Quote Originally Posted by koolair View Post
    I'm on 17.0.1128.0 20170419_0315(x64) 2017.2.1 which I believe is the latest and greatest
    Senior Member sdbrownaia's Avatar
    December 20, 2010
    889
    09:18 PM
    Yes, this is very annoying ESC twice has always gotten out of any command and back to modify. Having to click yes is just awful.
    December 13, 2010
    Ambleside, Lake District, UK
    743
    02:18 AM
    Great post - this behaviour in Text is so annoying it's worthy of Microsoft
    Gold Coast
    2,146
    12:18 PM
    Agreed. It's so ANNOYING.
    Autodesk
    February 22, 2011
    10
    10:18 PM
    Hi Dave et al--
    Help me understand your exact workflow, and what behavior wouild you like to see instead.
    Here is text note creation in Revit 2017+ (new text):
    Revit 2017+
    1. Choose Text tool
    2. Click in the view to start a new text note
    3. Type some text
    4. Click outside of the text note to complete it
    5. Double-click Esc to exit the text tool
    It sounds to me like the issue is that at step 5 you click Esc only once (the text tool remains active), then left-click in the view. This starts a new text note... but you didn't want that--and now clicking Esc twice doesn't exit the tool because of the "Do you want to keep the changes in your note" dialog box.
    Perhaps the solution would be to only fire that dialog if you click Esc after actually typing some text in the text box? If it's blank, as in your example, Revit should know that you don't want to save that text note.
    Does that sound reasonable, or do you have some other suggestions?
    Thanks,
    Trey
    trey.klein@autodesk.com
    Senior Member biff's Avatar
    June 13, 2011
    Australia
    701
    01:18 PM
    Quote Originally Posted by willsud View Post
    I would like to reply but my apple ipad2 keeps cras...h".i..wait for it......n........gggg
    Dave Jones and willsud like this.
    Mr. Revit OpEd
    2,408
    06:18 PM
    I've always just clicked outside the text field to finish text editing. I learned to never use ESC in past releases because that just killed the text editing work WITHOUT any warning. With 2017 it now warns you when you use ESC to help avoid losing the work. If you press ESC once and then Y it will choose the Yes response in the warning dialog. Using ESC twice chooses Cancel in the warning dialog, leaves you in the editing mode.
    Also, when they reworked the text editor for 2017 they assigned the combination of CTRL + Q as the default keyboard Shortcut for the command Close Text Editor, the Close button on the editor ribbon. You can assign your own but the editor HAS to have a CTRL key combination to work. Try using something else and a warning will pop up to let you know you can't.
    Edit: I just noticed that in 2018 there is no default keyboard shortcut for Close Text Editor. Also in 2017 and 2018 I find that when/if I use the Keyboard Shortcut a warning sound occurs each time. If I just use ESC and then Y...no bell. It seems to regard the use of the keyboard shortcut as some sort of error deserving of a warning, that's weird.
    Attached Thumbnails Attached Thumbnails Cancel Editing Text Grrrr!-2017-text-edit-close.jpg
  1. 2017 text editing problem
    By uros19 in forum Architecture and General Revit Questions
    Last Post: February 22nd, 2017, 11:45 AM
  2. editing user keynote text file protocol
    By ledgewood33 in forum Architecture and General Revit Questions
    Last Post: May 18th, 2016, 11:00 PM
  3. Editing dimension style, text offset Revit 2016
    By Robin p in forum Architecture and General Revit Questions
    Last Post: February 12th, 2016, 08:29 PM
  4. Revit OpEd: Text Editing and Zooming
    Last Post: October 18th, 2013, 03:15 PM
  5. How i can cancel my workset ?
    Last Post: May 13th, 2012, 11:18 PM
