Donate Now Goal amount for this year: 3000 USD, Received: 2527 USD (84%)
Results 1 to 3 of 3
Like Tree3Likes
  • 3 Post By Alex Page
Thread: Multi Category Tag Leader Alignment Issue
    May 31, 2016
    27
    10:57 PM
    Hi All,
    I have a multi-category tag which I am using in conjunction with general text notes to annotate an elevation (see image 1).
    The issue I'm having is that the general annotation notes all have their leader alignment set to the top (as can be seen with the "fixed roller shutter guides" note), whereas the Multi-Category tag leader alignment defaults to the centre of the body of the text...
    Is there a way to modify the MCT to get the leader to match the text?
    I've included an image (2) showing the parameters of the MCT label in the family editor.
    Regards,
    D
    Attached Thumbnails Attached Thumbnails Multi Category Tag Leader Alignment Issue-1.jpg   Multi Category Tag Leader Alignment Issue-2.jpg
    Senior Member Alex Page's Avatar
    Wellington, New Zealand
    569
    11:57 PM
    Yes
    MC tag leaders always start centered vertically, so put an invisible vertical line in centred on the hori refplane.
    If it is long enough (i.e. the extent of your invisible line is greater than the extent of your textbox) this will trick Revit into placing the leader to the middle of that line.
    May 31, 2016
    27
    10:57 PM
    Alex, you're a bloody genius mate! What a cheeky lil workaround - love it!
  1. multi leader tags
    By Darius in forum Architecture and General Revit Questions
    Last Post: March 2nd, 2017, 10:46 PM
  2. Building Coder: TextNote Leader Alignment
    Last Post: February 21st, 2014, 10:15 AM
  3. help with multi-category scheduling
    By oompa_l in forum Architecture and General Revit Questions
    Last Post: July 12th, 2013, 02:26 PM
  4. Leader and Keynote Alignment Issue
    By lilmac024 in forum Architecture and General Revit Questions
    Last Post: September 18th, 2012, 10:36 PM
  5. Multi-category schedule
    By Alfredo Medina in forum Architecture and General Revit Questions
    Last Post: September 12th, 2011, 08:37 AM
