Results 1 to 7 of 7
Thread: Walls are transparent n 3D view
    January 18, 2017
    Eden Prairie, MN
    47
    09:07 PM
    I am drawing an addition to an existing building. In the 3D view, on the New Construction phase, the new walls are showing transparent and the existing walls are solid. When I switch the phase to existing, the existing walls are transparent. I can't figure out why. Anyone experience this in the past? Using Revit 2016 Architecture.
    Member BD Mackey's Avatar
    November 1, 2013
    466
    08:07 PM
    Look at the phase settings, more than likely the phase material that is overriding the object based material is set to be transparent.
    January 18, 2017
    Eden Prairie, MN
    47
    09:07 PM
    Thanks, but that doesn't seem to be the problem. None of the phases are set to be transparent. When the phase filter is set to show complete, all the walls are transparent. There must be a setting that I am not aware of. Other projects behave normally.
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    2,403
    09:07 PM
    Is this just one View, or every 3D View?
    I have seen Views get corrupted. If that's the case, your only option is to re-create the View.
    One other possibility is those nasty old DWGs. Quite often if there's a DWG with some big wacked out coordinates, it can mes up a View.
    Try turning off the Visibility of DWGs in the View or, even better, get rid of the from your model.
    January 18, 2017
    Eden Prairie, MN
    47
    09:07 PM
    It's in every 3D view. Turning off the visibility of DWGs does not seem to help. I deleted the 3D views and created new ones but nothing has been successful.
    November 1, 2013
    466
    08:07 PM
    are all the walls the same material, has the transparency been set in the material or in the view graphics of a view template?
    8,567
    09:07 PM
    Brians first suggestion is it. Its in the Phase Filter OVERRIDES tab. New Objects should be set to *By Category.* If they are set to *Overridden* thats probably whats causing it.
  1. All of my walls are transparent?
    By jeeenyuss in forum Rendering and Gallery
    Last Post: February 1st, 2016, 03:57 PM
  2. Family with transparent colour plan view
    By aurimas in forum Architecture - Family Creation
    Last Post: November 27th, 2015, 12:59 AM
  3. Realistic View / semi-transparent in Revit Architecture 2014
    By colnagoboy in forum Architecture and General Revit Questions
    Last Post: April 10th, 2013, 03:22 PM
  4. Discipline view and non-bearing walls
    By LeanneZ in forum Structure - General Questions
    Last Post: August 5th, 2011, 02:36 PM
  5. Transparent Glass not transparent in Section View
    By Elisa in forum Architecture and General Revit Questions
    Last Post: December 17th, 2010, 06:02 PM
