Donate Now Goal amount for this year: 3000 USD, Received: 2290 USD (76%)
Results 1 to 3 of 3
Thread: window shows up in upper plans
    January 25, 2016
    4
    05:45 AM
    Hi There, I have some windows in the basement and they show up in the main floor as well, even though my cut plan in view range is above the main floor.
    Thanks for helping,
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    2,481
    03:45 AM
    EDit the Family and look at the Front Elevation view.
    There's probably something sticking up above the top of the window frame.
    Might be a line. Possibly an Invisible Line
    January 25, 2016
    4
    05:45 AM
    Thank You that was greate,
  1. Creating HVAC Layouts use ceiling plans or Floor Plans
    By fifthtexas in forum MEP - General
    Last Post: October 23rd, 2017, 09:58 PM
  2. Working with Tags, Lighting Plans, and Power Plans
    By mkisno4 in forum MEP - General
    Last Post: September 29th, 2016, 05:26 PM
  3. Staircase treads on floor plans and ceiling plans.
    By BIM Warrior in forum Architecture and General Revit Questions
    Last Post: November 11th, 2015, 07:34 AM
  4. Linking Callouts of Plans and Reflected Ceiling Plans
    By adamdr1 in forum Architecture and General Revit Questions
    Last Post: February 7th, 2013, 07:55 PM
  5. window shows profile on top of the window in the model
    By mno in forum Architecture - Family Creation
    Last Post: November 14th, 2011, 07:35 PM
