Page 7 of 7 FirstFirst ... 34567
Results 61 to 67 of 67
Like Tree14Likes
Thread: Documenting typical apartments
  1.    #61
    9,775
    09:46 PM
    Quote Originally Posted by guitarchitect View Post
    yah but these are 1:300 views of an 80m long building where the developer wants to see the type + size of unit, so having all the unit elements interferes with the clarity of the plans. so, we definitely have a good reason!
    We disagree, on what a good reason is. I do site plans with all the units on, too. But to each their own.
  2.    #62
    March 13, 2012
    51
    10:46 PM
    So if your client says "don't show the units, we just want to see what type of unit is where via the labels" you'd show them anyway because revit?
    I don't always agree with everything requested but sometimes I just do things to appease the powers that be, especially if they're paying our bills and giving us the next job.
    however, it's a huuuuuge uphill battle with some of the traditional cad guys. good lord. they can't even read plans properly when we have area reference lines displayed (the non-printing "x"s that show you where your areas terminate) and they want everything to look like their CAD drawings and excel schedules, so I have enough of an uphill battle as it is!
  3.    #63
    9,775
    09:46 PM
    Who said anything about "because revit?" I'd show them because the stuff is really there. At best, I'd halftone or lighten it, for the plan that just showed the overall unit labels.
    But showing a plan with the contents of the building core and shell, and the demise walls, and just "leaving out" the units... It wouldn't sit well with me at all.
    But, "the client demands it" would certainly make me do it. Absolutely. "Its at 1:300 so we think it's a really good reason" wouldn't.
  4.    #64
    Member anthonyB's Avatar
    August 31, 2011
    Sydney, Australia
    408
    02:46 PM
    Was chatting with someone offline about this thread and just wanted to add a couple of things:
    * Another reason for documenting apartments out of context: the Interiors team fully documented and completed "their" work in context, but then the stacking of the levels in the building changed so all of the wet area elevations needed to be adjusted. Who was going to do this?
    * Cross referencing another thread on Groups Best Practice https://www.revitforum.org/architect...er-models.html , including my own list https://www.revitforum.org/architect...-models-3.html
  5.    #65
    Member Bjorn_K's Avatar
    April 8, 2011
    Rotterdam, Netherlands
    282
    04:46 AM
    Quote Originally Posted by GMcDowellJr View Post
    Would you be up for sharing that?
    No problem, it was the first thing I wrote in Dynamo for Revit 2018(?) when we got the ability to add parameters to the Groups themselves.
    https://twitter.com/Bjorni_K/status/852862924653817859
    A bit more refined now, with Input fields to use in the Dynamo Player.
    The difference between what Aaron is using his for and this one is that I get the question a lot to split the contents of the units by the particular Unit Number. So not only do we have to split the real units from the "cloud" units, but then I also have to seperate my units.
    So my filters are the other way around, the cloud units have an empty value, the real units have the Unit Number. The presence of the Unit Number makes them show up in the schedules, the value of the unit numbers determines where they show up.
    Attached Files Attached Files
    GMcDowellJr likes this.
  6.    #66
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,033
    10:46 PM
    Roark 'em!
  7.    #67
    March 13, 2012
    51
    10:46 PM
    Roark 'em!
    Ha!
    I honestly don't see why it's a big deal. It's a graphic unit layout plan that's used as a marketing team reference... who cares about unit layouts. We have the regular drawing set for that.
  1. Documenting a family element
    By D_Incognito in forum Architecture - Family Creation
    Last Post: October 17th, 2016, 11:51 PM
  2. Documenting Grouped Units
    By GMcDowellJr in forum Architecture and General Revit Questions
    Last Post: February 12th, 2016, 12:28 AM
  3. David Light: Scheduling Apartments
    By David Light Blog in forum Blog Feeds
    Last Post: May 10th, 2013, 07:15 AM
  4. Documenting a Revit Library
    By LeanneZ in forum Architecture and General Revit Questions
    Last Post: December 21st, 2012, 07:15 PM
  5. Documenting the Revit Template
    By kpcarch in forum Tutorials, Tips & Tricks
    Last Post: August 16th, 2012, 10:42 PM
