Page 11 of 11 FirstFirst ... 7891011
Results 101 to 102 of 102
Like Tree25Likes
Thread: Documenting typical apartments
  1.    #101
    10,098
    01:49 PM
    Quote Originally Posted by sdbrownaia View Post
    The trick to that is how do you assure the users actually update the ones outside the main project and not edit group in the project, what if they edit a material in the host? they have to remember to do it in the outside project. Its a disaster waiting to happen. However, I have done that on ONE job where we had multiple apartment buildings on the same site that shared the same unit types, in that case I did have the groups as sep files, but I wouldn't do it again. Way too much management headaches.
    It gets way worse than that:
    Some Object TYPES (wall definitions, material definitions) simply WONT update when the group is reloaded from outside. Period. You get the "the type from the project will be used" message, and now you have disparities in your groups.
    If the unit cloud is the "worst thing ever" then tell them to put on their grown up pants and document all the units in context. It's the only "better way," and it's a lot slower to set up and maintain.
    Doing it in an outside file is LOL bad.
    tidalwave1 likes this.
  2.    #102
    July 10, 2015
    Boise, Idaho
    651
    12:49 PM
    That's good to know. The more reason to use the unit cloud the better
  1. Documenting a family element
    By D_Incognito in forum Architecture - Family Creation
    Last Post: October 17th, 2016, 11:51 PM
  2. Documenting Grouped Units
    By GMcDowellJr in forum Architecture and General Revit Questions
    Last Post: February 11th, 2016, 11:28 PM
  3. David Light: Scheduling Apartments
    By David Light Blog in forum Blog Feeds
    Last Post: May 10th, 2013, 07:15 AM
  4. Documenting a Revit Library
    By LeanneZ in forum Architecture and General Revit Questions
    Last Post: December 21st, 2012, 06:15 PM
  5. Documenting the Revit Template
    By kpcarch in forum Tutorials, Tips & Tricks
    Last Post: August 16th, 2012, 10:42 PM
