Results 1 to 2 of 2
Like Tree1Likes
  • 1 Post By snowyweston
Thread: Accessibility to parameters
    April 10, 2017
    11
    09:26 PM
    Hello,
    I've searched web and had no luck in finding answer to a simple thing, so I ll ask here...
    This is what I want to create with a Family:
    Step 1: The user checks the first parameter (Yes/No)
    Step 2: Once he does that, the other parameters become available.
    I'm pretty sure that this is possible. How can it be done?
    https://youtu.be/xK64a4gnyrk
    I will make a Family controlling types which differ not only by dimensions. Since it will require alot of parameters, I want to gray out the ones that are not in the user interest. If a user chooses a certain option, he will access new parameters. The whole idea is just to make it easier to read and follow.
    December 21, 2010
    C.LONDON
    4,343
    08:26 PM
    The example video you're referring to is an OOTB function, that Autodesk gifted themselves, being the program authors, that isn't exposed to us regular users in the same way (same applies to Y/N switches for a number of other items in Revit) - and the short answer is, no, not as you would appear to like.
    BUT
    There are ways to have "Input" and "Control" parameters, one that is exposed (often written in simple, user-responsive language), the other does the work, (but also catches any errors in the user entry), i.e.
    <Override Length> = Y
    <Custom Override> = 99mm
    <Length Control> = if(Override Length, Custom Override, 0mm)
    AndrejIlic likes this.
  1. Is BIM about to change the way you address accessibility of your building projects?
    By Serinela in forum Architecture and General Revit Questions
    Last Post: January 31st, 2017, 08:38 PM
  2. Replies: 0
    Last Post: January 24th, 2017, 06:45 PM
  3. Let's take building accessibility to the next level
    Last Post: December 12th, 2016, 07:17 PM
  4. Accessibility Plan Diagrams/Barrier-Free Requirements
    By AlloyDesign in forum Architecture and General Revit Questions
    Last Post: August 11th, 2015, 09:35 PM
  5. Best approach for creating an accessibility ramp from Architect?
    By tzframpton in forum Structure - General Questions
    Last Post: December 13th, 2012, 04:51 PM
Tags for this Thread
