Results 1 to 8 of 8
Thread: Spot coordinate origin
    September 2, 2015
    34
    02:46 AM
    Can you change the origin of spot coordinates? I want to base it off of a grid intersection without moving my base or survey points. is there a way to create a new point that will show up in the coordinate origin dropdown? or maybe putting a formula into the spot coordinate family?
    thanks!
    9,178
    04:46 AM
    You can make multiple setups for the Shared Coordinates (make another Survey point, basically).
    Mr. Revit OpEd
    2,469
    02:46 AM
    The Project Base Point is designed to be moved unclipped to allow what you describe. Then you assign a Spot Coordinate type to use Project Base Point as its reference.
    September 2, 2015
    34
    02:46 AM
    Can you tell me how?
    September 2, 2015
    34
    02:46 AM
    Steve i want to use multiple points as base points. basically have different spot coordinate types that have different grid intersections as origin points.
    9,178
    04:46 AM
    Oh, the method i described wont let you do that. You can go to manage > Location > Site > Duplicate, and make multiple coordinate systems. But the model can only ever be at one of the coordinate systems.
    You can do what you want with a really ghetto family, but its ugly and hacky. I did it back in 2007.
    Malleristic Revitation: Revit, Random, and different platforms...
    But i would much prefer use real coordinates.
    EDIT: if you really wanted to, you couple place "Markers" at certain grid intersections, and ask Dynamo to get coordinates based on different Markers... But that wouldnt be for the faint of heart.
    September 2, 2015
    34
    02:46 AM
    Thanks Aaron,
    that link looks interesting. When i get a little downtime i'm going to try to recreate it. You are correct, attacking that in Dynamo would be beyond me.
    Mr. Revit OpEd
    2,469
    02:46 AM
    Without a glimpse of the way your project is organized and documented in views and sheets...
    It might be feasible to move the Project Base Point (unclipped) to each key grid intersection and print the relevant sheets so spot elevations report the correct related coordinates. Don't add Spot Coordinate annotation that references the Project Base Point to any views that show more than one key grid intersection.
    Yes you'd have to be careful to place the PBP at the correct locations each time you print.
  1. Link Origin to Origin or Shared Coordinates?
    Last Post: April 25th, 2017, 12:18 PM
  2. Spot elevation with relative and absolute coordinate
    By mona miller in forum Architecture and General Revit Questions
    Last Post: December 22nd, 2016, 03:15 PM
  3. Snap Spot Coordinate to Intersection
    By cbaze in forum Architecture and General Revit Questions
    Last Post: August 29th, 2014, 02:21 PM
  4. Replies: 0
    Last Post: March 4th, 2013, 11:15 PM
  5. Revit Clinic: Project & Relative Coordinate Origin
    By Revit Clinic in forum Blog Feeds
    Last Post: July 8th, 2011, 10:20 AM
Tags for this Thread
