Donate Now Goal amount for this year: 3000 USD, Received: 2460 USD (82%)
Results 1 to 2 of 2
Thread: Text not wrapping
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    2,497
    02:11 AM
    Text not wrapping
    What controls whether or not Text Word-wraps?
    Or more accurately, Letter-wraps?
    I've got some Text elements in my template that don't wrap, even though the Text Box is smaller than the letters.
    I can create another Text using the same Style, and the new one wraps correctly.
    This is what it looks like in 2016
    The left one won't letter-wrap by adjusting the Grip of the Text box.
    If I edit the text, however, it immediately wraps.
    This has only become apparent with the upgrade to 2017, where the smaller box DOES wrap in 2017.
    Which screws up a bunch of Legends that were fine before and my Dynamo graph can't fix it because the Text Box is WAY too small instead of just a little too small.
    Or is this just one of those things that's been messed up forever?
    March 21, 2013
    Phoenix, AZ
    230
    12:11 AM
    Text wrapping appears to be a one way switch - once activated it can't be turned off:
    IsTextWrappingActive Property
    It does look like you can use Dynamo / Python to set the Width property of the TextNote to an acceptable value.
    This looks like it is related to the text-wrapping-changes-based-on-zoom-scale issue that was resolved in 2017.
  1. Schedule Text Not Wrapping
    By chompi0n in forum Architecture and General Revit Questions
    Last Post: November 6th, 2015, 04:28 PM
  2. Wrapping Issue???
    By AlexW89 in forum Architecture and General Revit Questions
    Last Post: January 6th, 2015, 11:10 AM
  3. Keynote Text Wrapping Issues
    By ThatBIMGuy in forum MEP - General
    Last Post: October 8th, 2014, 02:21 PM
  4. Question regarding wrapping
    By andreakset in forum Architecture and General Revit Questions
    Last Post: November 17th, 2011, 10:57 PM
  5. Room Name & Text Wrapping
    By Gabriel Black in forum MEP - General
    Last Post: August 16th, 2011, 01:11 PM
