Results 1 to 7 of 7
Thread: Wall Section strategy...
    Coeur d Alene, ID
    4,635
    05:13 AM
    So this was posted over at AUGI, thought I would ask about it here too...
    How are folks showing multi-level wall sections when they don't fit on a sheet at the required scale? What Rob and I came up with was to create dependent views of a section so that we can split them up on a sheet. Problem is this creates a 1A & 1B when all you want to see is a 1. On floor plan views I would stretch one of the section tags so they are beside each other, and would have to do this for any wall section with this circumstance.
    Anyone have better ideas?
    Orlando, FL, USA
    3,035
    08:13 AM
    What if you break a long view into smaller pieces by splitting the crop region, then moving the pieces closer. Then the view fits on the sheet.
    Coeur d Alene, ID
    4,635
    05:13 AM
    That is what we did originally before creating the dependent views...it was so cutup is was hard to understand what exactly was going on...
    Orlando, FL, USA
    3,035
    08:13 AM
    Yes, setting up the view by breaking the crop region into pieces might get a little hard to handle, but it is possible. We have done some wall sections with that method, and it works. Another alternative is this (see attached) : Create a callout view on the building section enclosing the wall to be detailed, then open that callout view, and create several detail callout views . Then work on the individual details, adding annotation, detail components, break lines, etc. Then, on the sheet, arrange those detail views vertically as if they were small pieces of the same crop region. It creates the same effect but it might be easier to handle.
    Attached Thumbnails Attached Thumbnails Wall Section strategy...-wall-sections.jpg
    Member renogreen's Avatar
    April 27, 2011
    Reno, Nv. USA
    335
    05:13 AM
    Do what we all did in the old-pre-computer days. Go to a smaller scale and then use details (callouts) to get to the interesting stuff.
    Coeur d Alene, ID
    4,635
    05:13 AM
    Quote Originally Posted by renogreen View Post
    We played around with that thought.....but when working with this particular client they like specific scales...
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,551
    12:13 PM
    Really, really extended sheet then?
    To be honest, I don't think that you can do this...
  1. how to create custom wall (lines of wall are not parallel)?
    Last Post: August 22nd, 2011, 03:11 AM
  2. You know that wall that automaticly fills in when you place a door into an ex wall?
    By Stuntmonkee in forum Architecture and General Revit Questions
    Last Post: May 24th, 2011, 08:37 PM
  3. Splitting wall section horizontally
    Last Post: May 6th, 2011, 06:32 PM
  4. Can't see roof in section
    By madsagger in forum Architecture and General Revit Questions
    Last Post: April 4th, 2011, 08:34 AM
  5. 3D Section Drawing
    By Kcooke in forum Architecture and General Revit Questions
    Last Post: December 15th, 2010, 10:21 AM
Tags for this Thread
