Results 1 to 9 of 9
Like Tree2Likes
  • 1 Post By chris.macko
  • 1 Post By Karalon10
Thread: Colors won't apply to the family in floor plan
    November 5, 2016
    37
    09:50 PM
    Unhappy Colors won't apply to the family in floor plan
    Hi everyone,
    I've been through a few topics in this forum but it seems to me that none of the have actually worked for me. My problem it simple: I've placed an original family (from revit 2017) in my project and set a material to it. However, the color I had set to the material just don't apply to it and it remains white no matter what. In the 3D view, nevertheless, the color I applied works just perfectly.
    I've already changed the level of detail, the consistent colors, the material itself (Created another one myself) and nothings seems to work. Surprisingly, it does not happen to every family, but just a few.
    Why is that?
    Attached Thumbnails Attached Thumbnails Colors won't apply to the family in floor plan-captura2r.png   Colors won't apply to the family in floor plan-capturar.png
    JCM
    JCM is offline
    December 17, 2010
    Pembroke Pines, FL
    571
    05:50 PM
    Have you checked if your view has any filters applied? or if there is an element override on the family?
    November 5, 2016
    37
    09:50 PM
    Nah I haven't set any filters. It is ******* me off the fact that only these families don't seem to apply colors
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,141
    05:50 PM
    There is most likely a masking region in the family. You would need to edit the family, get rid of the masking region and make sure that all of the geometry you need to see is set to be visible in plan and at the detail level (coarse, med, fine) required.
    November 5, 2016
    37
    09:50 PM
    Look, that's the family in the family editor. It has colors as well..
    Really dunno what's going on, but it seems to be the same thing for the sofa and the wall support I've placed in the other bed. For all the other families it seems to be working just fine.
    Attached Thumbnails Attached Thumbnails Colors won't apply to the family in floor plan-capturar3.png
    April 12, 2011
    Chicago, IL
    523
    04:50 PM
    Look at the family in plan view and see if there's a masking region like cellophane said. I think a decent amount of the autodesk furniture families have masking regions in them because that was considered best practice in the early days to help reduce CPU load. The 3d geometry might be set to not visible in plan as well.
    BasLn likes this.
    Senior Member
    December 16, 2010
    856
    07:50 AM
    you have color white set to both projection and cut surfaces, so that's why it is showing white. The color you have set at the top you have left "use rendered appearance" checked.
    Set your colors & hatching (if any) in projection and cut.
    BasLn likes this.
    November 5, 2016
    37
    09:50 PM
    oK guys, I've found out what was going on. Basically, the 3D model had all the colors applied on it, so the problem was the floor plan right? So I opened the floor plan and applied the "consistent colors" filter on it and guess what? all became white all of the sudden. There was a mask applied to it so I basically deleted it and changed the visibility settings of all the other geometries so it'd appear in floor plans as well.
    Worked just fine!
    November 5, 2016
    37
    09:50 PM
    Thanks everyone!
  1. Export Floor Colors to Color Scheme Dialog box
    By trevorpan in forum Architecture and General Revit Questions
    Last Post: June 14th, 2016, 04:25 AM
  2. Area Plan colors covering floor plan
    By Revitplz in forum Architecture and General Revit Questions
    Last Post: March 14th, 2015, 04:05 PM
  3. Noob Question: How to Print Part of a Floor Plan on Same Sheet With Framing Plan
    By colokate in forum Architecture and General Revit Questions
    Last Post: March 13th, 2015, 07:52 PM
  4. Duplicate and/or Rename a Floor Plan System Family
    By Joshua Kohl in forum Architecture and General Revit Questions
    Last Post: February 27th, 2013, 11:21 AM
  5. family colors in plan view
    By sohn in forum Architecture and General Revit Questions
    Last Post: September 19th, 2012, 11:54 PM
Tags for this Thread
