Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Like Tree1Likes
Thread: Needing more than custom keyboard shortcuts
    jcb
    jcb is offline
    April 14, 2017
    4
    10:08 AM
    Smile Needing more than custom keyboard shortcuts
    I've been using Revit for a number of years now, I was using AutoCAD and have not been needing to use that anymore .
    When I was using it I had been doing some programming with AutoLISP.
    What is the method in the Revit world to achieve the same kind of result but in the Revit world.
    I'm a keyboard guy, I don't like having to drill down 2 or 3 levels to get something done... with my mouse.
    I need to setup some command automation.
    Any suggestions will be greatly appreciated.
    "I am NOT a Revit tutor!"
    Dave Jones's Avatar
    4,523
    10:08 AM
    Quote Originally Posted by jcb View Post
    Hi and welcome to the forum! Try View tab/User Interface/Keyboard Shortcuts
    jcb
    jcb is offline
    April 14, 2017
    4
    10:08 AM
    Thanks, but I know where to access the KeyBoard Shortcuts on the menu. What I'm trying to find out is what to use or where to go to generate a macro that instead of having to drill down into sub menu and more sub menu's to get to something.
    Is there a Revit (AutoLISP), for the lack of words.
    Coeur d Alene, ID
    4,814
    10:08 AM
    Dynamo or create your own Add-in..
    jcb
    jcb is offline
    April 14, 2017
    4
    10:08 AM
    Great, thanks.
    Gold Coast
    2,631
    03:08 AM
    I still run an autohotkey script to combine several Revit keyboard shortcuts into one (WT&ZA for example).
    You say you want 'more than keyboard shortcuts' yet you only mention having to drill down 2/3 levels with your mouse, for what? To get to a button that could have a KS applied to it?
    edit, now I've read the thread properly lol, as Michael said, Dynamo or macros. For simple Revit/Windows commands, to automate dialogue etc, thats what I use autohotkey for.
    jcb
    jcb is offline
    April 14, 2017
    4
    10:08 AM
    OK, for example, I like to use the 'View-Specific Element Graphics' dialog to make things halftone. Pick Item/Right click/Override Graphics in View/By Element.
    What is 'AutoHotKey'?
    Gold Coast
    2,631
    03:08 AM
    Element halftone = EOH. It might even been a default shortcut.
    https://autohotkey.com
    March 13, 2012
    59
    01:08 PM
    If there are any shortcut whizzes reading this, Is there a shortcut to jump straight to editing the template that is applied to the active view? That drives me NUTS - when I just need to tweak some visibility, i hit VG and, oh, it's a template in this view. Select the view, go click on the template that is applied, etc. If you bring up the templates window (VT I think?) it doesn't pre-select the one you're looking at. It's such an annoyance, like many UI quirks in Revit that the programmers don't give a crap about.
    That being said, to the original poster, have you thought about getting an extra numpad or a macro board like an XKeys XK-24? Or a left-handed gaming/macro board? I haven't taken the plunge yet myself, but it's tempting.
    I'm slowly gaining more appreciation for the fact that anything in the ribbon can get a hotkey applied to it, including Add-ins. I share the frustration with the amount of mousing-around that needs to be done. Error messages are especially ingratiating - half the time I don't care what it says because I'm just trying to do some design work for a project that may never see the light of day, and it makes the design/modelling process painfully slow at times.
    Gold Coast
    2,631
    03:08 AM
    Quote Originally Posted by guitarchitect View Post
    If you're using VT to open the manage view templates dialogue then yeah, the one applied to a preselected view won't be highlighted. Pressing the view template button in your view properties will work though.
    I've tried a few gaming keyboards and pads but they've never really worked out for me, others on this forum successfully use X keys. There's even a radial menu written with Autohotkey if you're feeling adventurous.
    But I can get to 99% of my often used commands with a regular keyboard, with the most constantly used commands set to single keystrokes, move=1, copy=2, align=3...etc.
    I learnt early on to read the Revit warnings and it's taught me a lot about how Revit works (and doesn't work).
    Dave Jones likes this.
  1. Keyboard Shortcuts Not Working
    Last Post: August 10th, 2012, 11:20 PM
  2. Network Deployment - Custom Keyboard Shortcuts?
    By mzabritski in forum Architecture and General Revit Questions
    Last Post: September 30th, 2011, 04:46 PM
  3. Is there a way to print Keyboard Shortcuts
    By Wadeshuey in forum Architecture and General Revit Questions
    Last Post: June 17th, 2011, 10:13 PM
  4. Transferring Custom Keyboard Shortcuts to 2012
    By safoulkes in forum Architecture and General Revit Questions
    Last Post: April 14th, 2011, 09:17 PM
