Results 1 to 7 of 7
Thread: Shared Nested Family (Instance) Parameters not available in project?
    December 21, 2010
    C.LONDON
    4,343
    10:39 PM
    Following THIS THREAD
    I've just encountered the scenario I'd queried (regarding to controlling shared nested families) first hand, and I'm still a little confused...
    The attached family is an experiment we've been playing with to monitor/manage our office equipment - kind of like a pseudo-FM model, where we've also been playing around with our Roombook/ADB/Codebook functionality.
    It's a (shared) "workstation" - with instance parameters for CPU, GPU, etc.... nested within it is a (shared) "software" family, with instance parameters for, er software....
    Loaded into a project, the instance parameters of the workstation family are available, but once tabbed-through, the software family isn't. Placed singularly, the parameters are.
    This isn't how I remembered shared-nesting was meant to work...
    Do I have to add, and associate, ALL those paramters to the host as well?
    Attached Files Attached Files
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,551
    10:39 PM
    Yes it was, and always has been. I'm guessing you got confused with extracting the data through schedules. You can have the software family linked to the hardware family. Create a Mark-parameter in both families and nest the Software Mark in the Hardware family.
    IN your PROJECT environment you can now create schedules reading all Software parameters needed and identify those by Mark.
    9,906
    05:39 PM
    Type parameters are available through the Project. Instances must be tied to the Parent.
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,551
    10:39 PM
    Right, sorry: missed the instance part...
    December 21, 2010
    C.LONDON
    4,343
    10:39 PM
    And that's how I always understood it - a combination of wishful thinking and that other thread was throwing me off... the guy building these is just going to push the parameters into the workstation family out right...
    Quote Originally Posted by mdradvies View Post
    Any particular kind of parameter? I've just added a yes/no "Test_Mark" and associated them as you suggest, but apart from being able to tick it on/off (in the workstation family) nothing else appears to happen... in either way the schedule gives me the option to list all the (uneditable) parameters, but neither way gives me control over them.
    EDIT
    Again, it's no biggy, my guy's probably rebuilt it by now... I guess I was/am just having a bit of a late-Friday afternoon "wha?" moment.
    9,906
    05:39 PM
    The only ones you cant nest at all are Family Type parameters. Sucky.
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,551
    10:39 PM
    Ok, I dove in this since I do have a family for calculating egress length which has nested instance shared parameters but it still works... Only problem: I created this a year ago and never properly documented it.
    As it turns out, you CAN use Nested Instance Parameters, in the project. Just need a workaround. I posted a blog about this, find it here. And I attached the sample family with this post.
    Last edited by mdradvies; August 27th, 2011 at 12:51 PM. Reason: added link to blog
  1. Pull the shared parameters out of this project
    By Wadeshuey in forum Architecture and General Revit Questions
    Last Post: September 1st, 2011, 08:11 PM
  2. Company / Project Shared Parameters - where & how?
    Last Post: June 24th, 2011, 12:26 AM
  3. Specialty Equipment - Project or Shared Parameters
    By DaveP in forum Architecture and General Revit Questions
    Last Post: April 25th, 2011, 01:51 PM
  4. drive host through nested instance
    By mdradvies in forum Architecture - Family Creation
    Last Post: March 18th, 2011, 10:01 PM
  5. family and shared parameters
    By jbenoit44 in forum Architecture - Family Creation
    Last Post: March 2nd, 2011, 01:24 PM
