Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Like Tree13Likes
Thread: Landscape Master plan
    Member trevorpan's Avatar
    February 3, 2014
    Tempe, AZ
    198
    09:11 AM
    I'm about to start a church master plan. There will be site structures, shade structures, and walls.
    Any tips in how to approach the topo/site? Do you use the topo feature, or stick with floors?
    Thank you,
    8,582
    10:11 AM
    Ive been doing all of mine out of Roofs for some time now, and i would never go back.
    HOWEVER, enhancements in the Packages in Dynamo mean that if you HAVE a Civil file with real AEC Contours, you can go: Civil CAD File > Revit Topp > Revit Floros or Roofs through Dynamo, and get the best of all worlds.
    The attachments arent as large as a Master Plan, and they LOOK flat, but none of them are. Every strip of pavers is properly sloped for drainage, per the landscape design. All done of a single sloping control surface.
    With Dynamo, the control surface can be either topo or another floor or roof. So i used a control Floor, where i emulated the Landscape Designers Contract documents. Down at the ground, i used a topo built off the civil CAD file, and formed my Roofs/Floors to that.
    Attached Thumbnails Attached Thumbnails Landscape Master plan-2017-03-19_22-24-09.png   Landscape Master plan-2017-03-15_21-52-57-pavers.png
    Vangel, Nurlan and lawrenceolmos like this.
    February 3, 2014
    Tempe, AZ
    198
    09:11 AM
    Aaron, awesome project. Is it a hockey rink?
    What's up with revit's topo?
    I'll ask the surveyor about the contours. Seems like it they may be actual, the cad file's about 1600' above sea level. The roof idea sounds pretty good. I'll have to check in with dynamo...
    Thank youl
    8,582
    10:11 AM
    Its Hockey/Basketball/Rodeo.
    Revit's topo sucks for a number of reasons:
    1. Its not a real solid. For me this is a deal breaker. The BS method if makes you assign a base for ALL topo in elevation and section views, is garbage. I work on a lot of projects that have landscape above basements, or buildings dug in to the ground. Having to fight with a building pad to make the basement work, then fight with something else for the covering over the basement, is ridiculous.
    2. It cant have a real sketched shape. Outermost points form a perimeter, and thats it. If you want to make an L piece of topo, you have to lake the top, then split the topo, then delete a section. Thats insane. If you need to see an example of this bullshit, download Site Designer from Autodesk, and try to make a real parking lot that has grass in the parking lot islands. If you make an island thats at each end of a row, with the island continuous in the middle, youll see exactly what i mean. Trainwreck ensues.
    3. You cant give it real "vertical edges" at retaining walls. To be fair, Floors and Rofs dont do this perfectly either, but since i can put a floor on each side of a retaining wall so much easier, i dont even care. With Topo, it sort of "mudslides" through your retaining wall, unless the civil person meticulously placed a billion points right along both sides of the wall.
    In short... Topo (in my opinion) needs to (literally) be deleting from the program. The ONLY thing it does better than Floors/Roofs, is ease-of-editing through points (which Dynamo is almost taking care of) and visual style (since it makes topo softer, and shape edited floors and roofs are harsh. Youll want to turn off interior edges in the floor or roof subcat, in your view template), and the auto-creator from import, using civil cad files. Aside from that, Topo in Revit is a complete waste of space.
    Gold Coast
    2,147
    02:11 AM
    Aaron, how do you do develop your building pads now? Do you cut holes &/or use multiple family types with different thicknesses and join geometry?
    8,582
    10:11 AM
    Cut holes, and grade around.
    elton williams likes this.
    December 21, 2010
    Phoenix, AZ
    2,125
    09:11 AM
    Are you using floor/roof for non-hardscape areas as well or just for hardscape?
    trevorpan likes this.
    Gold Coast
    2,147
    02:11 AM
    Does that mean you have a floor as building pad to show cut earth underneath in building sections?
    How do you deal with steep slopes in floors and revit's warnings?
    I have a new project coming online but it has steep slopes to waterfront. I'd love to see this work, TIA.
    January 19, 2012
    131
    10:11 AM
    Aaron, do you create a floor/roof with a very thick variable layer, &/or both depending on situation?
    8,582
    10:11 AM
    Sometimes varying, sometimes not. Depends what is happening with the site and materials.
  1. Master plan nuggets of wisdom?
    By Raff in forum Architecture and General Revit Questions
    Last Post: March 10th, 2015, 02:14 PM
  2. Landscape
    By dhini.murdianti in forum Architecture and General Revit Questions
    Last Post: May 7th, 2014, 04:15 AM
  3. Sticky Notes: @StephenHamilNBS Level 2 BIM Master
    By Sticky Notes in forum Blog Feeds
    Last Post: December 18th, 2013, 10:45 AM
  4. Master Sheet Lists
    By ThatBIMGuy in forum Architecture and General Revit Questions
    Last Post: May 8th, 2013, 02:15 PM
  5. Omni Class and Master Spec
    By jmussett in forum Architecture and General Revit Questions
    Last Post: May 31st, 2012, 05:53 PM
