Results 1 to 4 of 4
Thread: A Schedule Question...How Do I...
    Member renogreen's Avatar
    April 27, 2011
    Reno, Nv. USA
    335
    04:41 AM
    We are doing a renovation of a hospital radiology department. We have to identify all existing walls containing lead and their associated rooms. I am trying to think of some way to create a schedule that will contain both wall information, type and area, plus the associated room info, room name and number.
    I am scratching my head. Is this even possible?
    December 21, 2010
    C.LONDON
    4,343
    11:41 AM
    Before you mentioned pulling the room info in I would have jumped at : "LEAD" YES/NO instance parameter for walls, , schedule filter for said parameter, show fields for area, type, comments, whatever.
    With room info, perhaps you could use a wall hosted family (empty of any geometry) - you should be able to schedule (out, with filters) that sole family/type in a room schedule.
    I am of course, suggesting all this without Revit to hand to test and verify.
    April 27, 2011
    Reno, Nv. USA
    335
    04:41 AM
    You may be on to something. One option would be to create an instance parameter, Lead, Yes/no and just create a couple dummy wall parameters for the room name and number and type that info in. I don't have a ton of rooms to do this with...maybe 10 or 12 total.
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,551
    11:41 AM
    I know it's not proper use of categories but use a Door or Window Family Template. Those are the ONLY ones able to automatically tie the Wall to a Room.
    Create a new Door. Delete the opening. Place a marker on both sides Exterior and Interior (2D symbol or 3D if needed). Now you can create a Door schedule, filter on this family and tie everything together with the room properties when you place them on LEAD walls.
  1. Revit MEP- question
    By JaredM in forum MEP - General
    Last Post: August 17th, 2011, 04:00 PM
  2. Schedule: Count only what's shown in schedule...
    By rkitect in forum Architecture and General Revit Questions
    Last Post: July 17th, 2011, 03:57 PM
  3. Roof Question
    Last Post: May 6th, 2011, 12:12 AM
  4. roof question
    By shiner79 in forum Architecture and General Revit Questions
    Last Post: February 22nd, 2011, 01:17 AM
