Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: project template upgrading
    April 28, 2011
    Iowa
    15
    06:40 AM
    So do you all create a new template for that years version, upgrade previous year and repath all family content in it to match new location or don't worry about paths? So you have a revit standards 2011 and a revit standards 2012 folders on the network with each project template pathed to the appropriate version.
    Member rosskirby's Avatar
    December 16, 2010
    Marietta, GA
    139
    05:40 AM
    I upgrade and repath. And the Labs released a different upgrading tool from the one that comes pre-packaged with the program (those batch and text files). The new one is an add-in that has a graphic interface and upgrades not only families, but also template and project files (.rfa, .rte, .rvt). All you have to do is select the source folder and the destination folder, and which file types you want to upgrade, and the add-in does the rest, including duplicating your library folder structure as it goes.
    United States
    1,137
    05:40 AM
    Quote Originally Posted by rosskirby View Post
    Will this go into the template and re-load all families with the correct pathing?
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,551
    11:40 AM
    Quote Originally Posted by gdoherty0102 View Post
    Not that I know off... AND this is a big reason why I have as little families in my template as possible.
    United States
    1,137
    05:40 AM
    That's what I am trying to do as well...that and getting rid of typical details, start using live cuts, go away from using colored object styles, have the default white back ground actually be white by default....
    December 16, 2010
    Marietta, GA
    139
    05:40 AM
    No, unfortunately not. All it does is upgrade your entire library of details and templates, along with the directory structure, which is pretty nice (especially compared to the previous tool). Maybe one day we'll get a decent "upgrade everything" tool, but until then, you're on your own manually re-pathing the families.
    United States
    1,137
    05:40 AM
    Figured, wishful thinking.
    Kingdom of Denmark
    4,204
    12:40 PM
    Just rethink how you structure your folders...
    Instead of:
    X:\Revit_Content\2010
    X:\Revit_Content\2011
    X:\Revit_Content\2012
    You could rename 2012 to "Current Version" (or whatever), and then when 2013 arrives, create a new folder named "2012", copy all the content from "Current Version" to "2012", and then run the batch upgrade on the "Current Version" folder.
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,551
    11:40 AM
    Quote Originally Posted by Munkholm View Post
    Instead of:
    sometimes the brilliant solutions can be soooo easy...
    United States
    1,137
    05:40 AM
    Instead of:
    This is how we did it before I switched it to having the date. The reason I did not like this method is because our version of Revit we use is governed by the Architect we will often use 2011 after we have deployed and have some project using 2012. So if I were to use this method when I convert all those in "Current Version" to 2012 all the people left working in 2011 can not use that link any longer and would have to go find where the 2011 files are stashed every time they need to load a family. By making it 2011 and 2012 I can completely leave the old version alone and not affect anyone still working in 2011.
  1. Building a Revit Template
    By Twiceroadsfool in forum Tutorials, Tips & Tricks
    Last Post: January 31st, 2019, 08:31 PM
  2. Baluster Template Warning
    By mark b in forum Architecture and General Revit Questions
    Last Post: July 4th, 2014, 06:39 AM
  3. Template Family Paths
    Last Post: July 12th, 2011, 02:00 PM
  4. View Template Best Practice
    Last Post: May 21st, 2011, 11:18 AM
  5. Upgrading Issue
    By Alex Cunningham in forum Architecture and General Revit Questions
    Last Post: March 17th, 2011, 12:57 PM
