Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Like Tree2Likes
Thread: 2017.2 View Reference Command made dumber
    April 22, 2011
    15
    06:32 PM
    Previously when inserting a view reference (ribbon - view - sheet composition - View Reference) the detail number and sheet would be listed alongside the view name for those views that have been already dragged onto a sheet. In 2017.2 the detail number / sheet number is no longer listed. A step backwards. Can anyone else confirm?
    Attached Thumbnails Attached Thumbnails 2017.2 View Reference Command made dumber-view-reference-dropdown.png
    Mr. Revit OpEd
    2,392
    09:32 PM
    I've still got 2017.1 installed at the moment and it is doing the same thing as you show which is strange because I'm certain that last week I saw the sheet and detail number values included while working on a different project file (also using 2017.1).
    Member pivoarch's Avatar
    March 16, 2011
    Hamilton, NJ
    249
    12:32 AM
    When you use a View Reference the detail and sheet number do not appear, however if you create a new view (callout, section, ect...) then click reference view you will see the detail and sheet information.
    Steve_Stafford likes this.
    April 22, 2011
    15
    06:32 PM
    Thanks Steve and pivoarch.
    pivoarch, yes I think you have solved it - that is what I was remembering. In everyday usage, when referencing the view, the detail number/sheet number is much quicker to select than long descriptive detail names (especially when numerous views listed). It would be great if Autodesk was more consistent with the User interface.
    Mr. Revit OpEd
    2,392
    09:32 PM
    Aah, you've identified the inconsistency and that explains my memory from last week. Thanks!
    New Member ravinnaidu's Avatar
    February 8, 2016
    Mumbai
    2
    05:32 AM
    Hi everyone,
    I have one problem with view reference callout. I have more than 800 views so its difficult to refer the view from drop-down list. Is it possible to type a number or view name so i can easily pick the reference view.
    Thanks
    Attached Thumbnails Attached Thumbnails 2017.2 View Reference Command made dumber-reference-callout.png
    April 22, 2011
    15
    06:32 PM
    Looks like you are on revit 2014. Version 2017.2 has a searchbox at the top of the list that could be of use in reducing the amount of views in the dropdown. Consistent naming for views also helps.
    tzframpton likes this.
    February 8, 2016
    Mumbai
    2
    05:32 AM
    Thanks for reply.
    May 3, 2012
    77
    04:32 PM
    That's not the only thing missing. Anyone else notice you don't have a 'search' bar when using the view reference tool?? It has it for callouts etc, not for view reference. It has been like that since the search bar came out in Revit 15 R2. I wish they would fix it..
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    2,372
    11:32 PM
    I had a Revit Idea suggestion for new Rooms, but it would apply here, too.
    Instead of the drop-down list, I'd like to be able to drag from a Schedule.
    That way we could sort, filter and search any way we wanted to as well as being able to use any applicable parameter, not just the one or two in the drop-down.
    Speaking of Search, I'd include a link, but I can't find my Idea again.
  1. View Reference tag that can display a view's name too not just sheet and number data?
    By basilmir in forum Architecture and General Revit Questions
    Last Post: March 16th, 2017, 09:45 PM
  2. Reference point short cut command
    By redmonki in forum Architecture and General Revit Questions
    Last Post: November 17th, 2016, 09:20 AM
  3. Revit 2017 Reference Plane Subcategories
    By BD Mackey in forum Architecture - Family Creation
    Last Post: May 28th, 2016, 01:13 AM
  4. Revit OpEd: Revit 2017 - Filters and Reference Planes
    Last Post: May 2nd, 2016, 09:15 PM
  5. View Reference for Reference Callouts
    By GMcDowellJr in forum Architecture - Family Creation
    Last Post: November 30th, 2012, 04:00 PM
