Donate Now Goal amount for this year: 3000 USD, Received: 2340 USD (78%)
Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By maciejwypych
Thread: Custom Railing for Curved Stair
    January 4, 2017
    Miami
    8
    05:39 AM
    I could use a few suggestions on creating a curved railing. I've tried a sweep in a "model in place" Generic Model, but I can not get the path to recognize the curved surface.
    The curved surface in the image is a mass with a divided surface onto which I drew a model line (3D Spline). I was hoping to use it as a reference to create the rail.
    Thanks!
    Attached Thumbnails Attached Thumbnails Custom Railing for Curved Stair-curved-railing.jpg
    8,848
    04:39 AM
    Is there a reason you dont want to use a Railing?
    January 4, 2017
    Miami
    8
    05:39 AM
    I can't get the railing to follow the path that I created. I also can't sketch a path on the surface....maybe I'm doing something wrong?
    Note the stair treads are not part of a stair family as the stair is not a true spiral, but more an ellipse, almost looks like an air foil.
    May 5, 2014
    Sydney, Australia
    137
    07:39 PM
    It can be easily done with adaptive components.
    Attached Thumbnails Attached Thumbnails Custom Railing for Curved Stair-ellipse-railing.jpg
    cganiere likes this.
    January 4, 2017
    Miami
    8
    05:39 AM
    Quote Originally Posted by maciejwypych View Post
    Thank you, I like that technique...wish I could do it without the facets....I used (50) on mine and it is pretty smooth, but seems like a bit more work (and poly's) than should be necessary. Very good for now though!
    Thanks again for the help!
    Attached Thumbnails Attached Thumbnails Custom Railing for Curved Stair-curved-railing-2.jpg
    8,848
    04:39 AM
    Quote Originally Posted by Warp Drive View Post
    "More" of an ellipse? Or an ellipse? Can you post the file here, so we can look at it? I dont see any reason to not use a Railing, yet. :shrug:
    May 5, 2014
    Sydney, Australia
    137
    07:39 PM
    Because you draw or pick a line if it's an ellipse. It seems that the railing tool (or the stair tool (even stair by sketch)) doesn't work with shapes other than line or arc.
    8,848
    04:39 AM
    If it's modeled (currently) as a *true ellipse* then break it down in to an approximating of arcs, and get on with modeling it with the railing tool. Using an adaptive component just to keep it 100% pure ellipse, is a bit... silly.
    I understand the technical limitations. Still no point to massing it out.
    January 4, 2017
    Miami
    8
    05:39 AM
    The stair...which doesn't meet any building code that I know of...is in the shape of an airplane foil. I could not use the stair tool to create at it as there are many different tread shapes. The treads are individual generic models and sit on sleepers not stringers. I saw a sweep used as an alternate method, but the profile does not stay parallel with the floor. The adaptive rail worked perfect, but is a bit more time to create and it is segmented of course.
    Can you share the procedure for using the railing tool? I understand following a series of arcs, but how do you define the upper and lower limits?
    Attached Thumbnails Attached Thumbnails Custom Railing for Curved Stair-3d-view-1.jpg
  1. Stair Railing
    By robledojuan7 in forum Architecture and General Revit Questions
    Last Post: February 10th, 2016, 02:02 PM
  2. 3 Run Stair Railing
    By Grumple in forum Architecture and General Revit Questions
    Last Post: September 24th, 2015, 03:33 AM
  3. Having issues railing a stair
    By jkwright2012 in forum Architecture and General Revit Questions
    Last Post: February 18th, 2015, 06:13 PM
  4. how to create custom railing for stair in revit ?
    Last Post: August 17th, 2011, 07:30 PM
  5. Custom Stair railing
    Last Post: July 25th, 2011, 11:02 PM
