Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By Darius
Thread: Custom room finish tag
    Member DesignApparatus's Avatar
    July 20, 2011
    San Diego, CA
    166
    12:26 AM
    Anybody have any advice on how to create a custom room finish tag that draws the info from the room like the Room Schedule does?
    Thanks
    Member Darius's Avatar
    May 6, 2013
    462
    03:26 AM
    so are u looking for a tag something like this.
    you would have to add the finish properties into the ootb room tag
    Attached Thumbnails Attached Thumbnails Custom room finish tag-room-tag-showing-properties.jpg   Custom room finish tag-room-information-properties.jpg
    DesignApparatus likes this.
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    2,372
    02:26 AM
    It's easy to add parameters (either current or new ones) to a Tag (provided they are Shared Parameters.)
    However, I suspect what you're really asking is "Can I pull the Materials from the Floor, Walls and Ceilings that define a Room's boundaries?"
    And to that question, the answer is "No".
    I don't know the programming reasoning behind that, but my guess would be that a Room can be bound by more than 4 Walls, Floors extend over many Rooms, and you may have several Ceilings in a Room
    July 20, 2011
    San Diego, CA
    166
    12:26 AM
    Thanks,
    That was the direction I needed. I modified the OOTB Room Tag and had it report parameters from the Room.
    Thanks!
  1. Room Finish Schedule
    By carter7343 in forum Architecture and General Revit Questions
    Last Post: October 6th, 2014, 02:27 PM
  2. Replies: 0
    Last Post: June 10th, 2014, 09:15 AM
  3. Room finish schedule.
    By Alfienoakes in forum Architecture and General Revit Questions
    Last Post: March 28th, 2014, 08:17 AM
  4. Revit Room finish parameters
    By ainebim in forum Architecture and General Revit Questions
    Last Post: May 30th, 2013, 01:24 PM
  5. Floor Finish Material to Room Tag
    By archizen in forum Architecture and General Revit Questions
    Last Post: May 28th, 2013, 01:14 PM
