Results 1 to 7 of 7
Like Tree2Likes
  • 2 Post By cellersick
Thread: Doors not showing up in revit floor plan
    January 4, 2017
    3
    06:16 PM
    Hello!
    I am having trouble with my doors showing up on the floor plan view in revit
    When i hover over the door it is there as it highlights (i am in hidden line view)
    however when i switch to wireframe then only it shows
    why is this so? how can i fix it for the doors to be shown on hidden view ?
    I have attached the photos for reference
    thank you ! help is neededdd~!~
    Attached Thumbnails Attached Thumbnails Doors not showing up in revit floor plan-wireframe.png   Doors not showing up in revit floor plan-untitled.png   Doors not showing up in revit floor plan-untitled7.jpg
    February 29, 2012
    61
    05:16 AM
    Hi there,
    Because the other doors are showing my guess is that the family visibility settings are preventing it from displaying or the door elevation is unexpectedly outside of the view range. Have you modified that door family or is the one that ships with Revit? If you haven't changed the door, then what is the Sill Height of the door? Does the door display when you change the detail level to Coarse or Fine?
    Best Regards,
    Glynnis
    January 4, 2017
    3
    06:16 PM
    The door remains the same if its coarse of fine detail level.
    the door is the one that comes with revit. I have not changed the door type. If it is a family visibility problem how can i change it so that i am able to see my doors?
    Member cganiere's Avatar
    January 5, 2011
    Orange County, California, USA
    209
    03:16 AM
    Have you verified that all the doors are in the same phase?
    March 21, 2013
    Phoenix, AZ
    275
    03:16 AM
    My guess is that you have a Floor that is above the Level the door is hosted on; the floor is obscuring the door swing symbol.
    MARIA1993 and tariknico like this.
    January 4, 2017
    3
    06:16 PM
    Thank you @cellersick! That was the exact problem i had 2 floors stacked over each other.
    February 8, 2019
    1
    05:16 AM
    so how do you fix that problem? how do you get the doors to show when you have a second level?
  1. Poche doors and display their width dimension on floor plan
    By a1e in forum Architecture and General Revit Questions
    Last Post: August 26th, 2016, 05:20 PM
  2. Scupper showing in floor plan
    By johnmc73 in forum Architecture and General Revit Questions
    Last Post: October 22nd, 2015, 09:54 PM
  3. Showing an HRV on a Floor Plan
    By BAMacPherson in forum Architecture and General Revit Questions
    Last Post: August 4th, 2015, 02:00 PM
  4. Keynotes from floor plan showing on ceiling plan keynote legend (and vice versa)
    By JonWPI in forum Architecture and General Revit Questions
    Last Post: September 3rd, 2014, 06:59 PM
  5. roof light showing on floor plan
    By paudiesf in forum Architecture and General Revit Questions
    Last Post: January 24th, 2013, 07:49 AM
