Results 1 to 2 of 2
Like Tree2Likes
  • 2 Post By snowyweston
Thread: Taging and specifying wall legend?!?
    December 22, 2016
    3
    04:23 AM
    I am trying to make specification for my wall types. The project i'm working on is not too big , but still there are plenty of wall types and finishes.
    I enclose the picture describing the situation, where i got three types of screed, and two types of tiles. I tried to create some main wall types, like load bearing concrete walls with different thicknesses, also gypsum board wall with different core thickness. Beside this i created all my finishes like different types of screed and tiles as separate walls.
    After i have modeled all the structure, i have applied the finishes, by modeling the finish wall and aligning it to a main wall (also joining them together).
    1. The main problem arises when i have to annotate and tag these walls. The tag snaps only to a specific type of wall with a unique type mark.
    2. The door cuts only the host wall, where it is placed in. So in some cases i got a jamb which wraps incorrect.
    3. When placing two walls in a legend i cannot align one to another, also i cannot put dimensions.
    So what is the best way to deal with this problem?
    Attached Thumbnails Attached Thumbnails Taging and specifying wall legend?!?-wall-legend.png   Taging and specifying wall legend?!?-wall-tag.png
    December 21, 2010
    C.LONDON
    4,382
    02:23 AM
    Quote Originally Posted by markarhitekti View Post
    That's "by design" - and for those that have adopted the multi-wall approach, requires the move to a slightly different way of working - either by:
    opt.1.: multi-tagging, (a tag for cores, a tag for linings, etc) which can be done on the same, or multiple different views/sheets
    or
    opt.2.: using "referred" view references to point toward a "mother" section (I presently do/advocate this)
    This is purely because you're working with the OOTB content - or at least content not setup for multi-wall modelling. The depths to which you can go working up doors/windows/etc (in the family editor) to account for this are endless... and a whole other thread topic in themselves.
    That's because Revit legends suck - and if you go with route opt.2 (above) using real sections, you will be able to rid yourself of them (not entirely, but certainly for this)
    All breezy answers I know, but a lot of this is 'old' news to a lot of us, and has been covered countless times on the forum before. Give the search a try - some really good reading on this topic to be had here.
    And welcome to the forum!
    cganiere and markarhitekti like this.
  1. Wall Type Component List/Legend from the Model?
    By Jj Mac in forum Architecture and General Revit Questions
    Last Post: June 16th, 2015, 03:44 PM
  2. Wall material tag to legend
    By andreakset in forum Architecture and General Revit Questions
    Last Post: January 24th, 2014, 07:17 AM
  3. Legend: Exist Wall, Demo Wall, New Wall.
    By doni49 in forum Architecture and General Revit Questions
    Last Post: May 29th, 2013, 06:00 PM
  4. Legend Component of a Curtain Wall Door
    By Craig Howie in forum Architecture and General Revit Questions
    Last Post: August 14th, 2012, 01:40 PM
  5. Wall Legend For Demolition
    Last Post: August 4th, 2011, 05:40 AM
