Results 1 to 2 of 2
Thread: Color Fill Legend - Transparent hatches have grey background not white..
    May 3, 2012
    1,403
    02:42 PM
    Question Color Fill Legend - Transparent hatches have grey background not white..
    Im using a transparent hatch in a colour scheme and in the floor plan it shows with the white background.
    However, in the legend it shows a grey background (and the minor inconsistency is annoying me...)
    I thought this might be the 'Default' material but changing that had no effect.
    Anyone know if this can be changed?
    Attached Thumbnails Attached Thumbnails Color Fill Legend - Transparent hatches have grey background not white..-capture.jpg
    jmk
    jmk is offline
    Forum Addict jmk's Avatar
    December 31, 2012
    NM, USA
    1,457
    06:42 AM
    There doesn't seem to be a way to do a transparent hatch for color schemes, and there aren't ways to do two color patterns without manually layering symbolic elements. If that is a room legend I'd try removing it and replacing it, and if that doesn't work duplicating the view, because graphic oddities like that can be a sign the view has corrupted.
    The default material shouldn't come into play in a color scheme. If this is a legend created manually there are a number of options (layered fill regions, filled region over existing model element, etc.)
  1. Color fill legend on sheet?
    By boriskam1991 in forum Architecture and General Revit Questions
    Last Post: July 8th, 2019, 11:58 AM
  2. Color Fill Legend
    By Gordon Price in forum Structure - General Questions
    Last Post: August 25th, 2016, 10:13 AM
  3. Replies: 6
    Last Post: February 15th, 2013, 03:01 PM
  4. Delete a Color Fill Legend
    By DaveP in forum Architecture and General Revit Questions
    Last Post: October 9th, 2012, 07:43 PM
  5. Color Fill Legend Catch-22?
    Last Post: January 27th, 2012, 04:07 PM
