Results 1 to 8 of 8
Thread: Working Views and Annotation Views - display of view callouts
    Member rosskirby's Avatar
    December 16, 2010
    Marietta, GA
    139
    05:41 AM
    Hi all.
    I'm having some difficulty in setting up the project browser in the template to differentiate between Working and Annotation views. Actually, setting up the browser to sort the views by the types was the easy part. The part I'm having difficulty with is that the view callouts (elevation tags, specifically), still show up in the floor plans where I don't want them. For example, my west elevation annotation callout shows up in the west elevation working view, and vice versa, since each view is a duplicate of the other.
    I don't want to have to manually hide the annotation callouts in the working views (etc.), so I thought a filter would do the trick. And it does...sort of. The filter will hide the active portion of the callout (the part you double-click on to go to the view it references), but it won't hide the callout head (the portion that references which sheet the view is on). Any ideas, or am I stuck manually hiding every new elevation tag several times?
    See attached image for reference.
    Thanks in advance.
    -Ross
    Attached Thumbnails Attached Thumbnails Working Views and Annotation Views - display of view callouts-screencap.jpg
    Rotterdam, South Holland
    3,039
    12:41 PM
    Ross, I assume you are defining the elevation views with a comment or some such and filtering on that? Because sadly, that doesn't work as you noticed. Because the part associated with the actual view is the arrow, so the reference bubble actually doesn't contain the same data, and thus doesn't filter.
    The trick I use is to have an actual Working Elevation type. I actually use the square graphic to highlight the fact that it should never be seen on a sheet. And because both the bubble and the arrows are of the Working type, you get the filter effect you are looking for. I even created a box based section bubble for Working sections to be consistent.
    Gordon
    Alex Cunningham's Avatar
    December 8, 2010
    Northern California
    3,567
    04:41 AM
    Quote Originally Posted by Gordon Price View Post
    Gordon
    I would love to see a demonstration of this Gordon!!! Sounds very nifty.
    3,039
    12:41 PM
    Quote Originally Posted by Alex Cunningham View Post
    See attached.
    Gordon
    Attached Files Attached Files
    December 16, 2010
    Marietta, GA
    139
    05:41 AM
    Ahhh, a different elevation type. Sometimes the answer is so obvious, it's impossible to see.
    Thanks for your help, Gordon.
    December 8, 2010
    Northern California
    3,567
    04:41 AM
    See attached.
    Gordon
    Awesome. This will work with our current standards. Great idea. Never even tried filtering this way. I wish i could filter by sub catatagorie
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,551
    11:41 AM
    Sweet trick, PotM!
    Member Exar Kun's Avatar
    August 2, 2011
    208
    10:41 PM
    That's the way I've set it up in our office too. I've got working sections and working elevations and view templates set to quickly hide or show these in each view. They're a different colour (red) to all my regular view annotations.
  1. Working views vs Printing views?
    Last Post: December 28th, 2012, 05:12 PM
  2. working in views through the sheet
    By cogan in forum Architecture and General Revit Questions
    Last Post: April 28th, 2011, 01:44 PM
  3. Behavior of Callouts in Dependent Views::
    By Jj Mac in forum Architecture and General Revit Questions
    Last Post: April 18th, 2011, 01:07 PM
  4. Views and View Templates
    Last Post: March 31st, 2011, 01:07 PM
