Results 1 to 10 of 10
Thread: Schedule Text Size *******ISSUE****
    Junior Member mpwolfe's Avatar
    February 23, 2016
    18
    10:03 AM
    Unhappy Schedule Text Size *******ISSUE****
    We have a template Schedule set up using 5/64" text height for header text, and body text. then we have 3/32" text height set for title text. for some reason every time we create the schedules on a sheet, the totals and blank rows blow up to a huge text size, of which we do not believe we specified.
    Is there any way to fix this issue?
    Junior Member JWelsh1990's Avatar
    October 30, 2015
    London
    30
    03:03 PM
    Hi Wolfe
    I till this day didn't even know there was such a thing as a Schedule View Template, So thanks for this will save some time in the future!
    out of interest if you create a new schedule, set the view template then remove it does the error remove itself?
    Thanks
    James
    February 23, 2016
    18
    10:03 AM
    No, it did not fix the error, the text sizes are fine for the schedule until it hits where it calculates totals at the bottom, then the headers and footers, and any spaces added jump to around 2 or 4 inches, and do not follow the size of the text already set.
    October 30, 2015
    London
    30
    03:03 PM
    Could you detail briefly what the calculations are please?
    I typically do very simple calculations in my models for example steel beams by type and then totally steel weight using a calculated value field.
    It might be easier if I could emulate the error myself to investigate, possibly with a stripped purged template file of yours.
    February 23, 2016
    18
    10:03 AM
    They are simple pipe length calculations, but regardless, this should not affect the text size of the footers and headers.
    Member lost again again's Avatar
    March 10, 2011
    Northern California
    367
    08:03 AM
    I can't quite remember why, but I've noticed that Revit 2017 schedules started in 2016 or earlier do not apply text styles per view template. I modify my schedule title text so I can sort schedules in the browser while avoiding incoherent titles on sheets. Lately, the title text will report a font and size, not the text type applied via view template. Check this by selecting the offending text and hitting the "ribbon > appearance > font" button: does it report the expected text type or something else? Possible workaround: select the text and hit "ribbon > appearance > reset" button. You will lose all previously applied formatting but regain control over the text.
    February 23, 2016
    18
    10:03 AM
    The problem with this is that you cannot click on the header and footers to change the text size manually.
    - - - Updated - - -
    February 23, 2016
    18
    10:03 AM
    I will just recreate the schedule and go from there, it should work then.
    February 23, 2016
    18
    10:03 AM
    Issue
    March 10, 2011
    Northern California
    367
    08:03 AM
    I was hoping my titles definition weirdness issue applied, but I see now that my workaround won't work for you. The view template can set the text type for "header", but Revit also calls the sorting parameters "headers". So the text type assigned to "headers" does not affect the other "headers". Sorry to not help.
  1. Text size does not update within project
    By gpktm in forum Architecture - Family Creation
    Last Post: January 14th, 2016, 04:17 PM
  2. parametric text size?
    By elance300 in forum Architecture - Family Creation
    Last Post: February 2nd, 2015, 02:50 AM
  3. Reduce VCD & FD text size
    By domsib in forum MEP - General
    Last Post: June 17th, 2013, 03:47 PM
  4. API app for text size
    By Patrick in forum Third party Add-Ins, API and R&D
    Last Post: February 17th, 2013, 09:34 AM
  5. text size in sheets
    By anjali in forum Architecture and General Revit Questions
    Last Post: November 18th, 2011, 09:42 AM
Tags for this Thread
